If the tub is raised off the floor, there should be an access panel to get to plumbing under the tub. Most RVs use the same slip fitting that is used in residential plumbing. There have been reports of the slip fitting not being tightened and slipping down. Check the plumbing, could be as simple as tightening the fitting by hand. If the tub is flush with the floor, you may have to make a small cut in the underbelly. Cut 2 sides and the back side to create a door with hinge to front. Re seal with eternabond tape.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
