Originally Posted by bobandpatsyrvers
All the hardware is good. What I need is the track that is above that suspends the door. The "rail" that the door rides on is starting to split and will soon have to be replaced. So far no luck searching on the web.
I was addressing removing the door. Once you have it down you can take the track to a "real hardware" store and id the one you have or change it to a real world set up. Make sure you measure top of door to ceiling to get your hanging clearance. Many homes have pocket doors, esp in the City. My problem was the securing screws. The two inside the wall were left slack at assembly, the door tilted. Like you made my arm 1/2 normal diameter and forced into the opening, got lucky problem solved.
