Old 01-04-2007, 09:41 AM   #1
Grand Surveyor's Avatar
Question Tornado installation
Looking for tips...Has anyone installed a tornado on the black water tank on a Grand Surveyor TT? I have a 2003 model GS272. I asked the dealer for a blueprint showing where everything is on the unit but was denied. I am hoping to be able to do this installation without removing more enclosed panels than I need to. Any tips are greatly appreciated.
Me, one great wife who navigates & researches places to go & food to eat, one little boy who can't get enough camping, one border collie who refuses to be left behind!
2004 Fx4 F250 King Ranch SVT CC, PSD, Prodigy, no mods.
2003 GS272.
Grand Surveyor is offline   Reply With Quote
Old 01-05-2007, 09:54 PM   #2
milzat's Avatar
Grand Surveyor,
I installed the Tornado Tank Rinser on my TT.
It's been a while sense I've looked under a Grand Surveyor, but I would think it has the same underbelly material (PP (Polypropylene) Sheeting) as my Rockwood. .
Here's what I did.
The Black Tank is located directly under the toilet. I removed a few underbelly retaining screws that hold the edge of the PP Sheeting in this general area. I pulled the material down a few inches and, using a flashlight, looked to see where the black tank was located. This gave me a good idea of where to cut the PP Sheeting to gain access to the tank.
When I located the tank, I took a rough measurement and marked the location. Using a Square, I cut a section (2’ X 5’) of PP Sheeting with a razor knife (box cutter). This gave me an open area to install the Tornado. After I completed the install, before replacing the PP Sheeting, I tested the tank rinser to make sure it operated properly and the supply hose and fittings did not leak.
I re-installed the PP Sheeting by placing a strip of FIR (2” wide, by the length of the cut) on top of the cut area, letting it overhang half way. I then positioned the piece of PP that I had cut out and screwed it onto the overhanging FIR. To seal the area where the PP met, I used black Duct Tape, then screwed a narrow strip of aluminum (the aluminum strip that is used at the edge of Linoleum flooring, it’s about 1-1/16” wide) over the tape.
SEE: Aluminum Strip “A” in the photo below.
Tornado
milzat is offline   Reply With Quote
Old 01-08-2007, 09:49 AM   #3
Milzat,
Thanks for the tips and photos. They are very helpful.
2003 GS272.
grand surveyor
