Old 08-28-2011, 06:09 PM   #1
Thurman's Avatar
Water pump operation
I've done the physical searching, and done the forum search, and cannot find the answer, so here goes: How does the water pump on my '06 FR GS291 work? I know it's 12 VDC, but what makes it come on? I cannot find a switch for this. One person told me it works when the water supply line is disconnected and it knows there is no water pressure. Then something switches it over to the 12VDC pump. Wrong! ! With the potable tank full, no water hose attached, any faucet open= no water pressure. I did find the pump and I checked the fuse, all looks good to go. So--is there a switch for it, or what am I looking for? Thanks, David
Thurman is offline   Reply With Quote
Old 08-28-2011, 06:13 PM   #2
DF5.4's Avatar
There should be a switch to turn the pump on. On both the campers we have had it has been on the tank level display.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 08-28-2011, 06:27 PM   #3
A switch turns on the circuit. The pump runs when the pressure sensor reads presure below a preset presure.
2012 Jayco 33 RLDS
2004 Chevrolet Avalanche 2500
2007 TBSS AWD
Hybrid21SS is offline   Reply With Quote
Old 08-28-2011, 07:24 PM   #4
TURBS's Avatar
the switch will normally be by your hot water heater switch or a central bank of switches for slide outs "if it has any"
anything like that ?
Old 08-28-2011, 09:08 PM   #5
TURBS's Avatar
switch panel
you may have a switch panel similar to this .
Old 08-29-2011, 05:39 PM   #6
Thurman's Avatar
DUH, do I feel like a dummy for sure. The switch was mounted with the tank level display. All I had to do was find that. It was in the bathroom, up under the medicine cabinet. Someone in engineering at Forest River surely laughed when they decided to place it there. But all works well. Thanks, David
Old 08-29-2011, 05:43 PM   #7
TURBS's Avatar
saweet glad you got it !
