Old 09-07-2015, 10:00 AM   #1
Shellback67's Avatar
Wiring diagram GS280
Having problem with battery being charged at too high a rate when plugged into ac power. Where can I find a wiring diagram??
2010 GMC 2500 4x4
2005 Grand Surveyor GS-280
Days Camped 2010 100+ on NC Outer Banks Fishing
Shellback67 is offline   Reply With Quote
Old 09-07-2015, 10:42 AM   #2
trbomax's Avatar
There are no "wireing diagrams" for FR units.I think they just string wire around and hook it up (or sometimes not) where ever it has to go. No color codes either.
trbomax is offline   Reply With Quote
Old 09-07-2015, 12:22 PM   #3
bikendan's Avatar
doesn't exist.
Old 09-07-2015, 12:35 PM   #4
If the converter is overcharging the battery, you don't need a wiring diagram. You need a new converter unit.
If it's a WFCO like the one in our previous unit it's about time to replace it. Ours lasted about 8 years in our 2006 GS-280.
You can buy a converter/charging unit for that converter.
What makes you think it's over-charging the battery, as opposed to it just being a bad battery?
Gotta go campin!
Old 09-09-2015, 05:19 AM   #5
It boiled the battery dry and charges at 19 volts.
2010 GMC 2500 4x4
Old 09-09-2015, 07:34 AM   #6
If it's charging at 19 volts and never goes into float then the charging section of the converter is bad. You can buy a new section at several places, but the best place I've found for sales and service is Best Converter. You can even buy a Progressive Dynamics unit to replace the WFCO if you want to.
Gotta go campin!
Old 11-01-2015, 08:08 AM   #7
Sc00ter's Avatar
The progressive dynamics is a drop in unit that directly replaces the wfco. Replaced the crappy wfco in our old tt with one and will do that swap again when our current wfco goes feet up. The pd unit is a much better quality and has a manual button to force it into bulk mode for fast charging.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 12-13-2015, 12:32 AM   #8
Never hear of a wiring diagram for ANY RV
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
280, diagram, wiring
