I had the same problem when I went from a Class A to the TT I could feel every time Jake would move around at night. your method of leveling sounds good consider doing this. make sure your wheels are chocked front and back both sides, if you have dual axles get X-chocks. use your stabilizers to take some of the weight off the suspension (I rase my rig about an 1" when stabilizing) consider installing a steadfast system or something like that. I did that and my rig is rock solid. Let the forum know the solution you use and how it works.
Retired Navy
2016 Flagstaff 26 FKWS
