Old 05-29-2013, 08:53 PM   #1
19RR Carry Can-Am Spyder AND Yamaha R1...
Will a Can-Am Spyder "AND" a Yamaha R1 fit inside a 19RR?
OmegaQuest is offline   Reply With Quote
Old 06-09-2013, 09:03 AM   #2
FYI, they do both fit but its very tight.
ID:	32705   Click image for larger version
Old 06-09-2013, 10:46 AM   #3
Looks good! I'm interested in the Can-Am and haven't done a whole lot of research on it, but what is the expected life of the engine? My Harley sits at 44000 miles and I expect it to go at least that much more with basic maintenance.
latner is online now   Reply With Quote
Old 06-09-2013, 11:24 AM   #4
It uses a rotax 990 v-twin engine which is known for being a very good, stable engine.
Old 06-27-2013, 11:20 AM   #5
Yol Bolsun's Avatar
Thanks for this post. Question tho, do you have enough belly clearance to load the Spyder easily or do you need to go thru one of the contortions I have read about on the forum (eg: jack the front end of trailer to max or extend the rear ramp in some manner)?
Also, is there plenty of room to get front left wheel back in far enough so that the snout doesn't get hit by the closing ramp/door? Keep in mind, my RT has slightly wider front wheel width and I still have fenders (just the wrong look for an RT).
Keith
Yol Bolsun! ("May there be a road!")
- 2013 Silverado CC/SB, 5.3L/3.08
- 2013 GW 21RR
Yol Bolsun is offline   Reply With Quote
Old 06-27-2013, 03:33 PM   #6
I had to lift the ramp up to get it in backwords.
I used wheel ramps that are meant to lift a car up so you can work on it from Advance Auto (I think they lift it 9" off the ground) and 2 jacks (on on each side under the TH ramp.
Not sure about the RT, but yes there is about 5" from the front nose to the rear of the ramp door when its closed.
Old 06-27-2013, 04:16 PM   #7
rattleNsmoke's Avatar
I'd love to try one of them backwards trikes
rattleNsmoke is offline   Reply With Quote
Old 06-27-2013, 09:39 PM   #8
Yol Bolsun's Avatar
Watch for Demo Rides in you area. They are a lot of fun..
Keith
- 2013 GW 21RR
