Old 07-13-2016, 11:20 AM   #1
2 Harleys in a 22RR?
So I started out looking at a 19RR. Then I considered the fact that sometimes we head to Key West in February or March and it can be impossible to ride the bikes so I might need room for a friend. Nice to split the costs too. Same with trips to Sturgis and beyond. So I'm looking at the 22RR now.
Yesterday I went to a dealer to take my own measurements. Today I'm going to chalk the floor plan on my driveway and see what happens. I realize that if they do fit it will be as tight as sardines which is fine with me. But I really need to make sure they will fit. Both are Harley touring bikes... a Street Glide and an Ultra Limited.
So the questions is has anyone actually tried it? The majority of my traveling is with the wife and one bike so I don't really want to jump up to a 26RR. I elk hunt in Montana and Wyoming and longer trailers can be a problem on sharp turns on mountain roads.
I've already looked at a few threads about raising the ramp at the rear so the bikes don't bottom out going up over the top of the ramp. My bike is really low. I can fix that but just need to know that they will fit. I've asked several dealers and my answers were yes, no, and maybe. lol Forest River themselves say yes but it will be tight. But I can't afford to find out they don't fit when it's too late.
Any input at all will be greatly appreciated.
Indian Summer is offline   Reply With Quote
Old 07-13-2016, 12:41 PM   #2
Usually Confused Member
emm-dee's Avatar
Prior to purchasing my TH I took the Harley to the dealer and loaded it to see the exact fit. I can easily walk all around a Road Glide Ultra but wouldn't want to try loading two of them.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 07-13-2016, 12:54 PM   #3
I have not looked at the 22RR but I love the 26RR, the cargo area is really nice to hang out in. Look at the spec differences, I did when I was looking. The 26RR is less than 2 Feet longer than the 22RR, and less than 200lbs heavier dry. I don't think that 2' difference will hurt you that much on the corners because of where the axles are located, it is less than a 1' difference. The bathroom is larger in the 26RR and the layout in the cargo area I think is much better. You dont have anything on the road side of the rig, where as the 22RR you do so you are limited in width. I learned with my last trailer to not go small, if you are torn between 2, take the larger one. Also, if you are thinking about hauling 2 full dress bikes, I dont think that will work in the 22RR. You will most likely end up trailering one and riding the other... This a great place to find your answer! I am sure someone will chime in on this who has a 22RR and tried what you want to do.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
Old 07-13-2016, 01:07 PM   #4
I had a 2012 21RR and no way are you fitting 2 Harleys in it. My Electra Glide took up all the space in it. I don't think two Sporters would fit either.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Nights camped 2016-43
Nights booked 2017-21....so far
Electra glide is offline   Reply With Quote
Old 07-13-2016, 01:09 PM   #5
Keystone's Avatar
Similar situation. South for a few weeks each late winter/early spring. Week in WI and another for Sturgis. Having a Trike (or two) and a bike narrowed the list of Toyhaulers quickly.
2015 W&P 25CB/ 2011 F250 6.7L Diesel
2015 HD FLRT/2009 HD XL1200L
US Army, 1979-1990 95BZ6
Keystone is offline   Reply With Quote
Old 07-13-2016, 08:22 PM   #6
wbdavey's Avatar
Maybe try one bike facing forward and the other rearward? Or stagger one a couple of feet forward of the other to prevent the fairings banging together. Use good wheel chocks like the Condor Pit Stop to hold the bikes vertical and then put a mattress between them? FWIW, I hauled 2 Heritage softails in a 6 foot wide cargo trailer.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 07-14-2016, 12:51 PM   #7
No way are you getting 2 HDs in a 22RR. We almost bought one, but measured at the last minute and got the 26RR instead. It's still a tight fit with a Softail Slim and a Honda ST1100. The price difference is minimal. Go for the 26RR.
2016 Cherokee Grey Wolff 26RR
2015 Ford F150
2015 Harley Davidson Softail Slim
1991 Honda ST 1100
Skoll is offline   Reply With Quote
Old 07-14-2016, 01:01 PM   #8
I have the 25RR & we can fit an Ultra & A softtail in it. No way 2 baggers. Ours wouldn't fit due to cabinets in the way. Don't know about a 22RR. Also agree - use a condor wheel chock.
JCUJ is offline   Reply With Quote
Old 07-14-2016, 04:04 PM   #9
RVBikers's Avatar
I think your bigger limiting factor will be your CCC. the brochure lists it at 2600#. A SG & an Ultra will take up about 1800# right off the bat, that only leaves you 800# for propane, water, clothes, food, and other camping equipment. The other issue is , the bigger trailer will have LESS Cargo Capacity. Good luck in your search though.
Jim & Evelyn
-2015 Ford F-350 XLT Dually
-2014 XLR Hyperlite 27HFS
-2012 Harley Davidson Street Glide (his)
-2004 Harley Davidson Fatboy (hers)
RVBikers is offline   Reply With Quote
Old 07-15-2016, 05:12 PM   #10
2006 Goldwing in my 19RR
Have to do one pic at a time or it gets flipped upside down.
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
harley
