Old 10-07-2016, 03:47 AM   #21
sgtlm17's Avatar
As ChipBruce said above, the members here have tons of knowledge and willing to help. Just ask and you will have more answers than you thought possible.
2016 Forester GTS 2801QSF
sgtlm17 is online now   Reply With Quote
Old 10-07-2016, 05:20 AM   #22
I might add that I have been surprised at how little propane the refrigerator uses. I thought it would use a lot more.
rjgrady is offline   Reply With Quote
Old 10-07-2016, 07:18 AM   #23
Thanks a lot for caring! Every one tried to help me above and beyond in a time I needed info!!!!!
•the reason I was ranting about the guy @ Cherokee is because he is the only context and has still not responded to me 3 days later! /and I want every one to know!
If I had a customer @ our Goodyear shops and they had to evacuate , I would atleast respond to the poor guy
16' Cherokee wolf pack 20pack10
Rzr 1000
Outlander 1000
ĽAll pulled by 15' Gmc 2500HD duramax
Ozziedodge67 is offline   Reply With Quote
Old 10-07-2016, 07:25 AM   #24
Like others said, these are all things that should have been covered during your PDI. Yes the main owners manual itself is not that helpful, but you should have also received separate manuals for each appliance, hot water tank, furnace etc.....
I have been dealing with Chad on warranty issues. He is the Cherokee service manager. Sure he doesn't respond right away, but I have been very happy with his turn around time.
2014 Chevy 2500 CC, Duramax
2017 Wolf Pack 25pack12 Toyhauler
polishdon is offline   Reply With Quote
Old 10-07-2016, 09:30 AM   #25
As a corporation owner I say 24hr call back max. We will see how he is In the long run
Rzr 1000
Outlander 1000
Old 10-07-2016, 09:40 AM   #26
Mr. Dan's Avatar
You give indications that you didn't take the suggestion made by bikendan in post #19. Have you contacted your dealer as bikendan suggested?
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 85 / 2017 = 14; booked = 28
Old 10-07-2016, 10:16 AM   #27
I believe you're trying to get answers from the wrong person. This forum has given you plenty of information, most importantly, to call the dealer you got it from. When I picked up my 25pack12 we did over a 2 hour PDI. They went over all the things you're asking and a whole lot more. I took notes, and along with all the owners manuals and this forum I have been able to answer any questions I had.
Old 10-07-2016, 10:33 AM   #28
Yes I contacted my local camper dealer. It is a local hole in the wall kind of place, good prices just not sir of knowledge.
I have listened to what every one has said and thanks every one here on the forum...
Was not trying to bad mouth any one on here.
If any one got the wrong picture I'm sorry
Rzr 1000
Outlander 1000
Old 10-07-2016, 10:42 AM   #29
Mr. Dan's Avatar
Yes I contacted my welding dealer. It is a local hole in the wall kind of place, good prices just not sir of knowledge.
How did the topic of welding get involved?
Old 10-07-2016, 12:55 PM   #30
Mis spelled and corrected that.
Ok I just want to verify I'm doing this correctly ... outside the camper on the water heater itself has a black switch on and off, and the on position I would assume is the electric way to do it if you have power supply. Make sure you have either pumped water or connected to the city water? Also when finished so I don't burn anything up I need to turn switch off and then unhook water supply?wither electric or propane I need the use the heater switch to heat up water
Rzr 1000
Outlander 1000
