Old 06-02-2017, 07:15 PM   #1
22RR Wall structure
Hello all, Still the newbie here!
First trip last weekend with the Harley in there there, was a lot of extra space in the back. Want to make some storage areas (back and sides) in that wasted traveling space. Anyone now what the studs on the walls are 16"on center or 24" on center. Thinking of putting E Track on the walls. Thanks in advance.
smithmx47 is offline   Reply With Quote
Old 06-02-2017, 11:32 PM   #2
I believe they are 10" to 12"
Aggitator is offline   Reply With Quote
Old 06-03-2017, 11:37 AM   #3
RiderBloke
RiderBloke's Avatar
My 26RR has them at 16" spacing on the walls and roof. Any seams with that thin strip covering are on a stud and any of the rings to hold the seats up are as well. I use the knock knock method to find them. I'm currently building a narrow cabinet to go from kitchen to rear wall on left and found the studs to screw that up strongly.
The floor runners/beams are not as easy to find and their position varies at different places. As I found out when I installed some extra rings.
Retired Intentional Interim Minister
Saginaw Valley BMW Riders
BMW Riders of Tampa Bay
Habitat Care-a-Vanner
RiderBloke is offline   Reply With Quote
Old 06-07-2017, 08:57 AM   #4
Do you have a stud finder? They work in the camper to! The studs SHOULD be spaced out the same so mark with tape of chalk so you can measure the spacing.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
Old 06-07-2017, 09:14 AM   #5
If you look real close at the walls you will see light white fill putty where they filled where they stapled the wall board to the studs. It blends in with walls but if you look real close you can see where studs in the walls are.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 06-07-2017, 10:08 AM   #6
That's how I found mine...especially when I added the cabinets above the driver's side bench.
2016 26RR and a 2018 OR371MBH
mxdad is offline   Reply With Quote
