Old 08-07-2015, 04:43 PM   #1
26 rr grey wolf outside tv
could anyone tell me where the splitter for the outside tv cable is , my picture is very fuzzy out side.inside in the bedroom and living room tv on cable works fine just the outside is bad.i checked the outside and inside outlets and no diffrerence so im guessing there is a splitter some where . i also did turn off the hd antenna booster so i know its not interfering with the cable . any help would be apreciated greatly . thank you
statticcling is offline   Reply With Quote
Old 08-08-2015, 07:17 AM   #2
Retired Techie
Cable connection
Found in another post that outside cable connection was miswired at the entertainment center. Sorry, nothing more specific.
moligney is offline   Reply With Quote
Old 04-11-2016, 06:42 AM   #3
How do you make the TV work with the radio speakers
gil56 is offline   Reply With Quote
Old 04-11-2016, 08:15 AM   #4
Retired Techie
Pull the plate on the ceiling with the tv connection on it. The splitter is crammed above the ceiling. Input from switch on tv plate, outputs to radio, bedroom, outside. Be prepared for a bunch of stuff to fall out of ceiling. FR calls it insulation, I call it chopped up left over cr*p. The speakers you will have to run tv audio to one of the rca (Not yellow) plugs on outside then set the radio to play that input.
2005 Wolf Pack WP22-2016 Grey Wolf 26RR-Gone
2004 Siverado 2500HD Duramax
2013 Keystone Springdale 5r
1998 Honda Valkerie
2016 Camping 148 days so far
grey wolf
