Old 02-22-2017, 10:18 PM   #1
smnavalley's Avatar
26dbh leaking slide
Just purchased our GREY WOLF 26DBH. Two days later, we noticed the slide was leaking while closed. Took it back to the dealer and it's still leaking. Seems the water is leaking from the upper rail. Has anyone else had any similar leaks?
2013 Ford F-150 5.0 Super Crew 4x4
2017 Grey Wolf 26DBH
smnavalley is offline   Reply With Quote
Old 02-22-2017, 10:29 PM   #2
SeaDog's Avatar
You can do a search for slide leaks and will find many posts about leaks and what they did to stop them. They are not isolated to type of rig the less expensive rigs have them as well as the very expensive rigs good luck.
Retired Navy
2016 Flagstaff 26 FKWS
Old 02-22-2017, 10:51 PM   #3
smnavalley's Avatar
Thank you!
Old 02-24-2017, 07:43 AM   #4
JustB_Rad's Avatar
I had this happen last winter to me. It was a bad bulb seal along the top. Watch all your woodwork too.....The veneer off of all my woodwork under the bunk and under the TV all popped.
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
JustB_Rad is offline   Reply With Quote
leak, slide
