Old 11-24-2015, 01:15 PM   #1
26RR flooring repair
Where to begin, how about not thinking before doing something leading to needing a repair. I have a 2014 26RR and have been using a motorcycle stand from Harbor Freight to secure my bike when hauling. On one particular trip, the stand shifted and tore the vinyl floor in a couple of places. I contacted the factory in hopes of getting a scrap piece to repair the torn spots but after a couple of email exchanges, I was told that they do not use that style flooring any more nor do they have any scraps laying anywhere.
I'm writing this in hopes that 1) a forum moderator from FR may have an idea on a source for a piece of flooring or 2) a forum member might have some scrap pieces from previous repairs they might be willing to part with and/or know where to get more. I know someone else that has a Coachmen camper and they have the same flooring so my hope is there is a source somewhere.
Any suggestions would be greatly appreciated, I do not want to replace the entire floor for a couple of tears.
Pictures are included.
Thanks!
ID:	94937   Click image for larger version
ID:	94938   Click image for larger version
Mr.P is offline   Reply With Quote
Old 11-24-2015, 01:29 PM   #2
Just A Member
EDABEUT's Avatar
In my old TT I cutout a piece inside a base cabinet of dinette to patch a hole. I then put a piece of carpet in the area I cutout to hide it. easy !!!!
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 11-24-2015, 02:18 PM   #3
jeff64's Avatar
Looks like you skinned the top coat. Can you get by gluing the flap with some contact cement? The imperfections you might camoflage with a sharpie or something like a minwax stain pen. Might be a whole less grief than cutting out pieces of flooring or putting a rug over it
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 11-24-2015, 02:56 PM   #4
Look in a storage area or under a dinette seat. Get the pieces you need from there and then install a neutral piece to replace the less obvious area. Be sure to get the vinyl Brand name and see a carpet store for the correct seam glue some vinyls react badly to the wrong seam glue. I know from experience.
hillsdaletc is offline   Reply With Quote
Old 11-26-2015, 04:35 PM   #5
Ours has the vinyl to front of bed. Possibly cut out a good section from there if yours is the same. Or just cover with a throw rug.
2014 Grey Wolf 25RR, 2012 F150 3.5ecoboost 3:55elocker 4x4 firestone air bags, 2004 HD Fatboy
0488FB is offline   Reply With Quote
Old 11-27-2015, 11:08 AM   #6
I use a piece of conveyor belt full length of bike and rubber horse matt cut into small pieces to protect floor.
I dont have a fix for your floor.
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 11-27-2015, 03:23 PM   #7
What setup is that bluewoo? Did you have to drill into floor?
drb1984 is offline   Reply With Quote
Old 11-28-2015, 09:11 AM   #8
No drilling. I use tie downs to front lower triple tree and one one the back wheel.
Bike has never moved, wheel chalk is harbor freight.
Rubber horse mat are mostly used as levelers for camper.
Utility Rubber Mat, Black, 4 ft. x 3 ft. - For Life Out Here
2006 Honda Goldwing
Old 11-28-2015, 09:30 AM   #9
What is the bar going across the 2 d rings
Old 11-28-2015, 10:16 AM   #10
1800 Lb Capacity Motorcycle Stand/Wheel Chock
2006 Honda Goldwing
flooring, repair
