Old 06-19-2015, 11:13 AM   #11
I found 2 wall joist and screwed in some eyelets and place a towell between wall and table and use a pull strap to secure.
Kickingupmudd is offline   Reply With Quote
Old 07-02-2015, 11:38 AM   #12
Originally Posted by fast6 View Post
How or where has anyone figured out the best place to store the oem table ??
I need the back bed so really leaving it at home isn't an option. I just cant see where they think this thing would stow away.
Pics would be great if anyone has ideas.
I installed a 3/4"x12"x24" piece of plywood on the wall above the wheel well. I furred it out with two 2"x 12" pieces of plywood for clearance of the bottom of the table glides. Be sure to use screws that are not too long that could possibly go through the wall. I attached two eye bolts to the plywood with them spaced about 12" apart. Stand the table on end with the legs toward the outside wall and push a rod through one eye bolt over the leg support of the table and into the other eye bolt. Will try to attach photos. Works great and was easy to do.
Name:   ImageUploadedByForest River Forums1435854978.761537.jpg
Name:	ImageUploadedByForest River Forums1435854998.526818.jpg
ID:	81895Click image for larger version
Name:	ImageUploadedByForest River Forums1435855016.032098.jpg
ID:	81896Click image for larger version
Name:	ImageUploadedByForest River Forums1435855036.959133.jpg
ID:	81897Click image for larger version
Name:	ImageUploadedByForest River Forums1435855054.897782.jpg
ID:	81898Click image for larger version
Name:	ImageUploadedByForest River Forums1435855069.164954.jpg
3greywolves is offline   Reply With Quote
Old 07-02-2015, 12:16 PM   #13
CTM
[QUOTE=3greywolves;911734]I installed a 3/4"x12"x24" piece of plywood on the wall above the wheel well. I furred it out with two 2"x 12" pieces of plywood for clearance of the bottom of the table glides. Be sure to use screws that are not too long that could possibly go through the wall. I attached two eye bolts to the plywood with them spaced about 12" apart. Stand the table on end with the legs toward the outside wall and push a rod through one eye bolt over the leg support of the table and into the other eye bolt. Will try to attach photos. Works great and was easy to do.
Great idea, but for the life of me I can't determine where you did it. Is it below the wall cabinets on the curb side?
2013 Ford F-150, 3.5L Ecoboost
2015 Grey Wolf 26RR
2008 Polaris RZR 800
CTM is offline   Reply With Quote
Old 07-02-2015, 12:43 PM   #14
I have a 27 RR and located it on the drivers side above the wheel well which is forward from the cabinets. You can locate it in another spot to meet your needs if you like. Worked well for me in that location and also can store a cushion next to it.
Old 07-02-2015, 02:35 PM   #15
CTM
3greywolves; no that makes sense, thought you had a 26RR.
thanks for the idea, it's a good one.
Happy Camping
2015 Grey Wolf 26RR
Old 07-29-2015, 10:00 PM   #16
pictures if you could still wondering what to do with table thought about putting on the bed and strapping down or strapping down on the floor dont want to fall on the bike while traveling
16grey is offline   Reply With Quote
Old 08-29-2015, 09:22 AM   #17
On mine I just show it between the fold up seats on the left side
clutchd is offline   Reply With Quote
Old 08-30-2015, 06:01 PM   #18
I just finished a quick release mount for my 26rr. I bought 3 rear ramp bumpers and two fold out bunk latches. This set up could be mounted on either side at the folded up couch. I cut the center out of the bumper 3/4" wide and screwed 3 to floor. The table sits in the groove cut out nicely so no damage to the table or flooring. Table sits at 90 degrees to the floor and then mounted the two fold out bunk latches. All you have to do is spin the handles to loosen and then they flip up allowing table to set down. Table ends up being where you want to use it. You can even pull out the extended base and easy to handle with 1 person. I have plenty of room with Harley bagger or my 4 wheeler next to it. Also I noticed that it stands even with the straps not hooked up.
ID:	87328   Click image for larger version
ID:	87329   Click image for larger version
ID:	87330   Click image for larger version
muttmutt is offline   Reply With Quote
Old 08-31-2015, 12:20 PM   #19
RiderBloke
RiderBloke's Avatar
Good job. Best idea yet for the table in a 26RR. I store mine in the basement. imagine how much better it would have been if the legs folded flatter against the table. Ah! Well!
Sent from my iPad using Tapatalk
Retired Intentional Interim Minister
Member of the BMW MOA
Saginaw Valley BMW Riders
RiderBloke is offline   Reply With Quote
Old 09-01-2015, 10:55 PM   #20
Sockman's Avatar
I don't have a 26RR, but I have the 19WP which has a very similar setup. I've never taken that miserable, awkward, over-weight, unhandy table with us on any trip. We do use our rear bed, though, so I needed something to span between the two couches. I took a piece of plywood that was thick enough to handle the weight of sleeping peeps, cut it in half, hinged it, then made an opening for a handle. When not in use, I simply set it behind the folded up couches. Works great!
Name:	folding rear bed support.jpg
ID:	87545   Click image for larger version
Name:	folding rear bed support 2.jpg
ID:	87546   Click image for larger version
Name:	folding rear bed support 3.jpg
2011 Wolf Pack 19DFWP
Sockman is offline   Reply With Quote
