Old 05-10-2018, 04:14 PM   #1
26RR Ramp door construction
Is anyone familiar with the construction of the ramp door on the 26RR. I recently purchased a 2018 and need to attach some legs to the edge of the door.
wchl25 is offline   Reply With Quote
Old 05-16-2018, 07:35 AM   #2
Do you want to permanently attach the legs to the door? I have seen some folks using removable jack stands for that.
How do you like your 26RR? I will pick mine up this week, anything you found at the PDI that I should keep an eye on?
ToysNtrailer is offline   Reply With Quote
Old 05-16-2018, 04:27 PM   #3
Yes, I am looking to bolt these jacks to the door. I need the door to be held at a specific height to add extension ramps.
We love the camper, my only complaint thus far was the mattress in the bedroom was lousy. We bought a memory foam mattress instead. We didn't find anything wrong with it at the PDI and have had no issues with it yet.
Old 05-16-2018, 04:51 PM   #4
Here are the jacks.
Old 05-19-2018, 11:40 AM   #5
Here are the jacks.
Those look nice. Where did you find them ?
On your unit is there a battery kill switch? I remember seeing it on the model we looked at when we ordered it but it didn't come with our 26rr..😔
Old 05-20-2018, 05:10 AM   #6
I mounted those jacks on my 26rr. I used the hole at the top of the ramp where the rubber bumper was mounted and drilled a second hole on each side. I used a piano hinge to mount the extension for easier loading of our motorcycle. Works great
2018 f150 ecoboost
2016 greywolf 26rr
Harley Davidson ultra classic
Jeramy is offline   Reply With Quote
Old 05-20-2018, 06:06 AM   #7
Do you have any pictures of your extension set up? What size is your extension and what did you use for material?
Loaded my Harley last fall in my Wolfpack 25/12 and was a little harrier than I like
Triple J is offline   Reply With Quote
Old 05-20-2018, 06:52 PM   #8
Ill get some pictures of it tomorrow. I used a 4x4 piece of 3/4 plywood for the extension. I got the hinge from e-trailer it's pretty heavy duty. I also put a couple pieces of angle iron under the extension just for extra measure. It's much easier to load and unload now. I can touch flat foot the whole way in and out.
Old 05-24-2018, 04:00 PM   #9
Hope this helps.
ID:	173206   Click image for larger version
ID:	173207   Click image for larger version
Old 05-24-2018, 05:36 PM   #10
Thanks, just like I figured but now I can show Mamma before I do it. LOL
Old 05-26-2018, 12:39 AM   #11
Jeremy, I see two springs on your ramp door. Mine has only one. Did you add the second one? I need more help getting the ramp up & down.
IndianKen is offline   Reply With Quote
Old 06-03-2018, 02:02 PM   #12
No I didn't add any springs. Adding the ramp does make the door heavier. But still manageable
2018 f150 ecoboost
2016 greywolf 26rr
Old 08-07-2018, 09:44 PM   #13
Hope this helps.
Very nice mod Jeramy! How long is your ramp extension ~ from the piano hinge to the ground end?
This would be fantastic to add on our 26RR, currently packing extra ramps and small jacks along now to help load without bottoming out.
extxn is offline   Reply With Quote
Old 08-08-2018, 05:27 AM   #14
jd50i's Avatar
Look at the 2019's, they have a cable that hold the ramp up to make a deck. Should easily be added to a 2018 and all you do is disconnect the cable for ramp use.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 08-08-2018, 09:10 AM   #15
My extension is 4'x4'. It works very well for our harley Davidson.
2018 f150 ecoboost
2016 greywolf 26rr
Old 08-08-2018, 09:27 AM   #16
Hinge
Hope this helps.
Jeramy. Got a few questions / requests. Can you send a closeup of where and how exactly you mounted the hinge. Can you sent the dimensions of the additional ramp. Did you look into a sheet of aluminum plate for the ramp? Sorry for all of the questions. Thanks
CB1753 is offline   Reply With Quote
Old 08-08-2018, 02:46 PM   #17
Additional Ramp
Hope this helps.
Jeramy, couple more questions please. What type of screws did you use to attach. Is there any other support under the additional ramp.
thanks
Chris
Old 08-08-2018, 05:36 PM   #18
I am not going to be by the camper for a couple weeks so I won't be able to get any more pictures. The piano hinge I got from e-trailer and mounted it to the top edge of the door. I just used some stainless sheet metal screws. I put a couple pieces of small angle iron under the extension for a little more support. I looked into aluminum but it was more expensive than I wanted to get into. I'm sure a piece of diamond plate would work fine. I mounted the support jacks at the top of the door where the rubber bumpers were.
Old 08-08-2018, 08:49 PM   #19
What size patio hinge did you use, the 2" or 3".
Old 08-08-2018, 09:37 PM   #20
I used the 3" it's 6 feet long I just Cut it shorter
2018 f150 ecoboost
2016 greywolf 26rr
door
