10-27-2015, 11:21 AM
Retired Techie
26RR Ramp extension
Extended my loading ramp by 24" as Valkyrie was to close to bottoming out loading. Modeled after one on my WP22.
1 2' x 4' x 3/4" Plywood
3 Heavy duty hinges
12 metal screws
1 can black paint
2 2 1/2 inch rubber bumpers
2 3" x 1/4 lag bolts
Only tricky part is choosing hinges that leave a 3/8 " gap so extension can angle down
2005 Wolf Pack WP22
2016 Grey Wolf 26RR-Traded in
2004 Siverado 2500HD Duramax Sold w225,000
2013 Keystone Springdale 5r Sold
1998 Honda Valkerie Sld
2016 Camping 148 days so far Bought park model and moved to Florida.
11-09-2015, 04:45 PM
Retired Techie
Bike Tie Down
Got the bike properly positioned finally. First try I had to much weight on tongue I felt. 1250 lb of 6990 lb was to much. Moved chock back 18" to 135 " from gate to front of HF chock. This should move some weight back and allow me to carry some weight in the waste tanks forward without getting nose heavy.
Gate extension worked good and chock position allows getting bike on the flat before front wheel enters chock.
I know getting TT tail heavy will cause it to sway but what will getting it to nose heavy cause besides the obvious exceeding CCC of TV??
2005 Wolf Pack WP22
11-10-2015, 07:40 AM
How did you mount chock to floor?
11-10-2015, 08:20 AM
Retired Techie
Medium duty tie down @ 135". There is a 2x3 stud running lengthwise down center. Used a studfinder to find it then a 3" hole saw.
2005 Wolf Pack WP22
11-10-2015, 08:25 AM
Do you have any pictures of the install
11-10-2015, 09:04 AM
Retired Techie
No but it is just a HF chock with a bolt welded to go through the tie down.
2005 Wolf Pack WP22
11-11-2015, 10:55 PM
Ok. Thanks. I guess I'm not sure which tie down to get and what style.
11-12-2015, 08:54 AM
Retired Techie
I used the medium duty. Just like the 6 already installed. There are different ways to hook the chock to it. I welded a bolt sticking out the front that fits through the tie down with a couple big washers and a nut
2005 Wolf Pack WP22
11-13-2015, 09:54 AM
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
05-19-2016, 12:24 AM
Where did you get the longer rubber supports? Are they really needed? Could I in theory just add a paver block under the existing supports? Also where did you get the hinges? I'm hoping to copy your idea this week
05-19-2016, 07:59 AM
Retired Techie
Most times I just used the rubber supports. Finally found them on the internet. Where the back was down hill I used the plastic "Leggo's". Had them anyhow for leveling. Got the hinges at Ace hardware just squar good sturdy hinges.
2005 Wolf Pack WP22
05-19-2016, 07:41 PM
2005 Honda VTX 1300
05-19-2016, 07:46 PM
I like that, where did you get the famous and levelers
05-19-2016, 07:47 PM
Ramps, not famous....
05-19-2016, 07:48 PM
And are they rated for 900lbs? My bike is heavy
05-19-2016, 08:21 PM
It's built as sturdy as the door is. It is only 3 ft long (should have bought 4 ft). My bike is 8 ft. Long so only half of the bike weight is on it at a time. My bike is 670lbs and I'm 240lb. Have no issues. It's stronger then me using 3/4 inch plywood as an extension.
https://www.amazon.com/gp/aw/d/B0009...?ie=UTF8&psc=1
Above is the link. Below is how it is constructed on bottom
2005 Honda VTX 1300
05-19-2016, 08:22 PM
Thought about using something like this. They claim to sit 9 1/4" off the ground. Just prop the door up to where I can butt these right up to it and be level and just drive up on it.
05-19-2016, 08:26 PM
What about the adjustable levelers? Where did you order those
05-19-2016, 08:28 PM
Those suckers have a lot of weight and then they have that well that the tire will sink into.
I feel good about my set up. But that's me everyone has their comfort level. My wife is not as comfortable as I am and leaves when I load and unload bike. Even with just the door. If the park has some small hills I will park at bottom and just use door.
2005 Honda VTX 1300
05-19-2016, 08:30 PM
26RR Ramp extension
Amazon. I helped buy Bazo's new mansion with all my purchases.
https://www.amazon.com/gp/aw/d/B0085...?ie=UTF8&psc=1
2005 Honda VTX 1300
