06-02-2016, 04:02 PM
26rr vents
So I'm getting ready for my big trip and have never hauled my bike in there yet. Since I'm bringing it this time I thought about the possibility of using the front and rear side vents. Do you all use these when hauling toys? Do you open them to be streamlined with trailer or opposite way to force air in?
06-02-2016, 04:30 PM
I was told not to open towards the front because the air can catch them and blow them out. Sounded good to me so I didn't do it. Just my 2¢.
Sent from my Nexus 7 using Tapatalk
Chip Bruce, RPh
Kansas City, MO
06-02-2016, 05:15 PM
Thanks, do you open them the other way
06-02-2016, 05:39 PM
I didn't. Only hauled my bike twice. Should have opened them. I couldn't figure out how on my 26rr. I have a different trailer now and it is much easier. On new trailer they rotate around the bar on the inside. Someone else will have to definitively answer the how on a 26rr.
Chip Bruce, RPh
Kansas City, MO
06-02-2016, 06:22 PM
on the 26rr ,you open the front one out and the back out and the air flows in the front and out the back, they only open one way
06-02-2016, 07:45 PM
On my 26rr they rotate on a bar in the inside as well and you can open both of them either way. It makes sense to me to open the front on where it will create "drag" for lack of better words, bc it would force air into the camper, and the rear where it was aerodynamical...but I didn't want the wind to rip it off as previously mentioned. Just wondering how everyone else did it
06-02-2016, 07:50 PM
In the summer, we open both vents toward the rear and our roof vents with all weather covers while traveling with or without our toys onboard to reduce static heat build up. Let's the ac work as designed upon arrival.
06-02-2016, 07:54 PM
That is the best thing I've heard today. Thanks for sharing this!
Chip Bruce, RPh
Kansas City, MO
06-02-2016, 08:10 PM
Towards the rear you mean where they are aerodynamical with trailer
06-02-2016, 08:17 PM
26rr vents
They are open to the back of the trailer. If we opened them forward, they would gather our luv bugs in the spring and fall and all our Florida liquid sunshine almost daily when on the road.
06-02-2016, 08:34 PM
I here ya, I'm in Florida as well
06-02-2016, 09:20 PM
I almost always travel with mine open..... keeps the gas fumes under control. Front open to the front, rear open to the rear.
As far as drag goes, the I bet the 18 or so square inches won't matter against the square footage on the front of the trailer.
2016 26RR and a 2018 OR371MBH
06-02-2016, 10:35 PM
And no problems with the wind catching and blowing it off I assume?
It only seems to make sense to me that's how you'd open them
06-03-2016, 06:01 AM
I would only ever open facing rear while traveling. The air will still circulate. Just think of the old sunroofs that use to be in cars. You would open them facing rear and the air would circulate through.
I would not want one to rip off. Sometimes I travel with mine open facing rear and sometimes have them closed.
I guess my bike tank is sealed good because I do not get gas smell with my bike inside.
While stopped I open them and turn on fantastic fan and it circulates the air nicely. I have a max air cover over fan.
So with this cover I do keep the fantastic fan open when traveling.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
06-03-2016, 07:19 AM
How does the max air cover mount?
06-03-2016, 08:35 AM
4 small screws in the a
Upper part of fan assembly casing. Then mine cotter pins to brackets held by screws for easy removal and cleaning.
2005 Honda VTX 1300
06-03-2016, 08:37 AM
Mounts like most all others.
06-03-2016, 10:04 AM
Is that the maxxair 1 or 2? I see the 1 says it's not for high powered vent fans and the 2 says it is
06-03-2016, 10:05 AM
I'm also thinking about getting the smoke one to block some of the light that comes into the bathroom
