Old 10-16-2016, 02:48 PM   #1
rotorhead1250's Avatar
27 RR fresh water tank vet
2017 27RR, first weekend out, first issue. Why does the fresh water drain have a T off it that runs a line back up to the screened vent next to the fresh water gravity fill? The overflow/vent tube is 10 inches long and goes straight down. I'm not a hydrologist, but it would seem that the overflow/vent tube should be the one that runs 6 feet back up to that vent. Why in the world would the drain line need to be vented?
Matt & Kathie
2017 Grey Wolf 27RR
rotorhead1250 is offline   Reply With Quote
Old 10-16-2016, 02:52 PM   #2
http://www.forestriverforums.com/for...cture16282.jpg
And of course its sideways. That is the fresh water drain with the T that runs back to the vent next to the fill.
Matt & Kathie
2017 Grey Wolf 27RR
Old 10-16-2016, 03:13 PM   #3
Sounds like your tank isn't plumbed correctly. Vent line should be off the top of the tank; drain off the bottom of the tank. Are you sure the line off the drain Tee isn't going to the pump?
PS: your link in Post #2 doesn't take me anywhere (or maybe I should say there's nothing there when the window opens).
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 10-16-2016, 03:25 PM   #4
Isnt this the City water connection?
GREYCAT is offline   Reply With Quote
Old 10-16-2016, 03:45 PM   #5
Not city water. Here's a gravity fill. See the small screened opening at about the 8 o'clock position. That's the vent.
Old 10-16-2016, 06:52 PM   #6
Second post was a pic of the drain line. I must say that I didn't trace that line all the was back up, it gets lost in the insulation, so your probable correct that its the pump feed line. It parallel's the fill tube. The over fill tube just hangs down next to the tank about 8 inches. I mostly dry camp in the forests, so max water is important to me. I'm thinking I will install a ball valve that I'll leave open during filling, then close it for traveling so the tank doesn't slosh half the water out. I don't know if anything is connected to that screened vent at the fill port.
Matt & Kathie
2017 Grey Wolf 27RR
Old 10-16-2016, 09:01 PM   #7
Yes, it's very possible the vent has come loose from the fill port and has fallen down. That would explain why you're losing 1/2 your water.
Either putting back on the fill port or installing a ball valve should fix the loss of water problem.
Old 10-18-2016, 10:25 AM   #8
Talked to mechanic and was told that manufacturers aren't running the vent tube back up to the vent, saves time and money. So it's practice now that the vent tube is just an 8 inch run next to the tank!?!? I'm going to install a ball valve in that short vent line so I can close it while traveling to the woods stopping my fresh water from sloshing out while driving. I'll open it once parked to allow the tank to breath during pump operation.
Matt & Kathie
2017 Grey Wolf 27RR
Old 10-18-2016, 10:33 AM   #9
rotorhead:
You might want to put a "flag" on your fill connection to remind you to open that vent before filling. The consequences of filling with no vent are DIRE.
(ex SH-3 Sea King/H-46 Sea Knight electrician)
fresh water, tank, water, water tank
