Old 07-06-2016, 08:20 PM   #1
27rr axles
Can anyone tell me the axle rating on the 27rr? My 26rr had 3500lb axles and I was wondering if they used the same axles on the 27rr? With the extra weight of the slide and camper I would hope for 5000 lb axles. If anyone could help I would appreciate it
drb1984 is offline   Reply With Quote
Old 07-06-2016, 08:42 PM   #2
Usually Confused Member
emm-dee's Avatar
Probably still 3,500 pound axles. Look at the specs...max weight is 7,934 and tongue weight is 934. So, two 3500 pound axles plus 934 tongue weight. You'll see the same calculations published for all the RR models..2x3500+published tongue weight will give you the same number as published max weight.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
axle
