Old 09-23-2015, 07:14 PM   #161
Ok, finally had time to trouble shoot this, the top fuse labeled "bedroom" was blown. There was a red L.E.D. light next to it as well telling me it was blown but I apparently did not get that far in my manual reading. This one fuse runs the following lights: next to front bed, over sink, range hood light and fan, both lights in garage area located over the benches and the electronic thermostat. Does this also have something to do with my fridge not working on gas? Not sure about that yet. So lesson learned, red light on is bad. Also picked up several spare fuses for future use.
2015 Grey Wolf 27RR Limited
2011 Dodge Ram 1500 5.7L Hemi
2011 H-D Ultra Classic
BKM1066 is offline   Reply With Quote
Old 09-23-2015, 07:48 PM   #162
Toby's Avatar
The first thing I would do is to go light the stove. Sometimes you might have air in the lines. Then reset the fridge and see if it works.
2012 Ford F-150 EB 3.73
2015 Forest River 25RR
2004 Honda GL1800
Toby is offline   Reply With Quote
Old 09-26-2015, 07:33 AM   #163
Thanks Toby, looks like everything works now, fridge and furnace. Have trip planned to Copper Harbor, MI in a couple of weeks.
Old 09-26-2015, 10:50 AM   #164
Sockman's Avatar
That seems to happen frequently. Have had the same problem.
2011 Wolf Pack 19DFWP
Sockman is offline   Reply With Quote
Old 09-28-2015, 07:54 AM   #165
Toby's Avatar
Yea if you turn the gas off at the tank then that happens. Maybe it's the regulator. I have no idea. I just know that whenever I turn my tanks on, I go light the stove. Then everything just works. I turn my fridge on two days before a planned trip.
2004 Honda GL1800
Old 10-06-2015, 02:17 PM   #166
what is the size of the tires and the load range on the 27RR?
kcmusa is offline   Reply With Quote
Old 10-06-2015, 05:33 PM   #167
I got my new 27RR last fall....carry two 735lb Harley deluxes in Condor chocks in garage...water heater plugs in under mattress plywood..NEVER PLUG IT IN ALWAYS USE THE GASHEATING OPPERATION...faster n better ! Was at several campgrouns this summer, the last being Little River Casino Campground for our steelhead and salmon flyfishing trip....The Refrigerator WILL NOT RUN ON GAS...unless the trailer is just about perfectly level and plum ! Have 18.500 miles on china bomb tires...carry two china bomb spares...next month we get 80 psi tires from Michelin and new rims....and pease of mind !
juice5 is offline   Reply With Quote
Old 10-06-2015, 05:49 PM   #168
mele's Avatar
Great TV!!!!!!!!!
Originally Posted by gilwilliams101 View Post
So my wife and I have a 2015 RZR XP1000 Desert Edition and looked high and low for a TH that had a garage deep enough to fit the RZR. The RZR is 10'6" long and therefore that eliminated all the 8x10 garaged THs. Then we got to measure a 27RR. Perfect fit! Tight, but will work. The local dealer already had one ordered with all the options and it's on the way. We will be pulling it with a 2015 RAM 2500 4wd Cummins 6.7 so the truck shouldn't be a issue.
My only concern is the RZR weighs 1700 lbs. which really limits my 'other' cargo weight. Hopefully all will be well. The RV dealer is telling me to get the E2 hitch. Any thoughts good or bad about this set up?
We are new to the TH/travel trailer thing and have been making a list of what to buy before we head out. Here is the list, If I am forgetting something, please smack me upside the head. LOL
30 amp cord
30 amp extension cord
Rhino sewer hose and extension
garden hose
water pressure regulator
water filter
90* elbow for water hose
Winegard carryout G2 for Direct TV
Direct TV receiver
RV toilet paper
Chemicals for treating tanks?
Michelob Ultra
Yeti
Michelob Ultra
Propane portable grill
Hose to connect grill to camper port
Michelob Ultra
Mat to go under awning (assuming 6x15?)
Bedding supplies
kitchen crap
bathroom crap
red sangria
broom and a mop
Is that all?
Thank you all for your input!!!
Gil
2016 FR Vengeance 25V Toy Hauler
2015 Ram 2500HD CC 4x4 6.7L Cummins
2004 Kawasaki Vulcan 2000
2005 Troy Built 3500/5250 Genny
mele is offline   Reply With Quote
Old 10-07-2015, 08:38 AM   #169
Toby's Avatar
Mine isn't all that picky but I keep a level in my fridge and level my camper by that. It has been working good.
2004 Honda GL1800
Old 10-07-2015, 01:50 PM   #170
mine are ST205175R14 AND LOAD is max single 1760lbs and max dual 1570lbs. Not sure of manufacture.
grey wolf
