Old 03-03-2016, 12:01 PM   #261
This one too: party deck and options
racenviper is offline   Reply With Quote
Old 03-13-2016, 10:26 PM   #262
I'm a new member -- just registered. We're pretty new to the RV thing, bought our first travel trailer ('14 CrossRoads Zinger 26BL) last spring, but now realize that bringing our toys along with dramatically improve our camping/travel experience. Our Zinger has 7ft (84") ceilings, which was one of the factors that sold us on the Zinger, especially for the wife. I've spent countless hours researching and physically looking at travel trailer toy haulers that are within the weight capacities of my '99 F150 long bed w/5.4L & tow package. I just bought a 300cc trike (93"L x 46"W x 570lb) for the wife, I have a Kawasaki ZRX1200R (84"L x 31"W x 500lb) and a Yamaha DT175 (83"L x 34"W x 215lb). Hauling those three would be Load A, which would be typical on a longer trip. For a typical two-night trip, we'll take Load B, which would included the Yamaha, along with a Polaris Trail Blazer 250 (75"L x 47"W x 490lb) and a Kawasaki Brute Force 300 (75"L x 43"W x 540lb). I'm pretty confident that Load A will fit in a 27RR, but I'm not so sure about Load B. The garage is too narrow to fit both four wheelers parked next to each other (straight in), but I may be able to pull one in, turn it 90 degrees, then pull the other straight in along one wall, and pull the Yamaha straight in next to it. But the biggest issue may be the low ceiling height (78") in the Grey Wolf, which is 6" lower than our Zinger. When we looked at a 27RR in January, a few seconds upon entry, my wife said "no way" because of the low ceilings. The Palomino Puma XLE29FBC has a very similar layout to the 27RR, but it's not quite as nicely appointed, but it does have 80" ceilings and lighter interior colors, giving it a more open feel. We both really like the new Venture Sport Trek 302VTH (aluminum/fiberglass w/10ft garage), which has 84-96" ceilings, murphy bed, and a similar layout to the 27RR and Puma, but it's $3000-5000 more than those two and it's pushing 6800lb UVW and is 35ft long. I'm not going to get another truck just so I can pull a heavier trailer, so the 302VTH is really not something I should seriously consider. I've brought "open floor plan" trailers into the mix, due mainly to lower weight and/or taller ceilings, and the one that fits just about every requirement we have is the Wolf Pack 24PACK14 with gel coat walls, 90" ceilings, 102" wide exterior, electric bed, seamless counter top & sink cover, 8cf Norcold refer, nice bathroom, and real walkaround bed with hinged doors for privacy (wife likes). With over 14ft of "shared" cargo space, the WP has more usable space than the 27RR and Puma, but obviously it doesn't have the advantages of a separate garage. Because of the additional foot of ceiling height and 6" of width, the WP feels huge inside compared to the GW. Two other open floor units I've looked at are the Coleman (Dutchmen) CTS250TQ (82" ceiling) and the Dutchmen Rubicon 2100 (84-96" ceiling). If we had to pull the trigger on a separate garage unit, our choices are very limited, and it would probably end up being the Puma because of the 2" higher ceilings than the 27RR. What do ya'll think? Are there any other light weight TH with separate garages? Is the open cargo area the better choice?
Red Barchetta is offline   Reply With Quote
Old 03-14-2016, 08:39 AM   #263
I have yet to find anything else thats not a 5th wheel and out of the 1/2 ton pulling range.
nickgindy is offline   Reply With Quote
Old 03-14-2016, 09:15 AM   #264
rmac04401's Avatar
The 24pack14 is similar floor plan to the 26rr. Just has compressor and fueling station and wider ramp door. I believe that is over 9000 lbs. that's why I went with 26rr it did not go over my weight limit for 2002 f150. I don't think your loads would work in grey wolfs. Seems heavy loads. There is only about 2600lbs cargo capacity in mine. Once you get all gear in. My one bike pushes the max weight.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2002 F150 5.4L extended cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is online now   Reply With Quote
Old 03-14-2016, 10:14 AM   #265
Also the Grey Wolf Rr models are on a travel trailer frame verse a Toy hauller frame. These ones arent really made to load down with much.
Old 03-14-2016, 07:19 PM   #266
My maximum "toy load" would be less than 1400lb, so capacity wise, I'm well within the GW limits. The low ceiling height is the biggest issue with the GW product.
Old 03-22-2016, 12:02 PM   #267
Qwiktime's Avatar
Does anyone have an idea of what to do with my spare tire on my 27rr like a good place to mount it or mod I can do they just set it in my back area on the floor not mounted.
Qwiktime is offline   Reply With Quote
Old 03-22-2016, 12:10 PM   #268
rmac04401's Avatar
27RR Grey Wolf
This is what I did. Have not checked tongue weights yet. But should be well within limits. Click image for larger version
Name:	ImageUploadedByForest River Forums1458662922.174540.jpg
ID:	102581Click image for larger version
Name:	ImageUploadedByForest River Forums1458662950.504822.jpg
Fits in between my under bed drawers I installed. You can go to the thread pimp my 26rr to see other mods that would work in your 27rr.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
Old 03-22-2016, 12:15 PM   #269
This is what I bought for my 26RR: Hide-A-Spare, 70" I-beam Underslung Mount - BAL 28218 - Tire Accessories - Camping World
Gets it up out of the way, and that is a good price! Normally it is over $100 everywhere I looked.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
Old 03-22-2016, 06:26 PM   #270
Toby's Avatar
I like the ideas on the spare tires so far. I just stacked two under the bed over by the water tank. If I ever need them it'll be an episode to get them out. I got two because if one goes the other was overweight so it automatically becomes a spare. My dealer advised me against mounting it on the back door which was my original thought.
2012 Ford F-150 EB 3.73
2015 Forest River 25RR
2004 Honda GL1800
Toby is offline   Reply With Quote
grey wolf
