Old 03-22-2016, 05:28 PM   #271
rmac04401's Avatar
There is one member on here that did bolt it on the back door. Bought the tire holder from Amazon.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2002 F150 5.4L extended cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is online now   Reply With Quote
Old 03-29-2016, 09:49 AM   #272
Qwiktime's Avatar
Generator mount
Does anyone have pictures of a mount for the front with generator and or storage box? I would like to be able to remove the generator while camping so as not to vibrate through the camper at night while sleeping.
Qwiktime is offline   Reply With Quote
Old 03-29-2016, 05:41 PM   #273
Qwiktime's Avatar
Thanks for all the help this page gives.
ID:	103241   Click image for larger version
ID:	103242   Click image for larger version
ID:	103243   Click image for larger version
ID:	103244   Click image for larger version
ID:	103246   Click image for larger version
2002 Avalanche, 2008 Suzuki, M109R, 1979 Malibu, 2016 Grey Wolf 27RR too many toy's not enough time!
Old 04-03-2016, 07:47 PM   #274
Back ramp door not lining up
So we just picked up our 27rr Friday evening and just tried the rear ramp door a few minutes ago. It was hard to pull down the upper right corner but thought maybe the seal was just sticking a little bit. When I went to close it I noticed it's not lined up correctly. The left has a decent gap and the right is hitting the screws. Has anyone else had any issues and/or know if I can adjust it?
Avalanche is offline   Reply With Quote
Old 04-03-2016, 07:56 PM   #275
RiderBloke
RiderBloke's Avatar
Did your dealer not check it? I would talk to them about it. It could be that something is bent or poorly fitted.
Sent from my iPhone somewhere on the face of the earth using Tapatalk
Retired Intentional Interim Minister
Member of the BMW MOA
Saginaw Valley BMW Riders
RiderBloke is online now   Reply With Quote
Old 04-03-2016, 08:12 PM   #276
I haven't had a chance to call them yet. The dealer was 2.5 hrs away and we never checked the ramp before we drove it home. Figured that would be something the manufacturer would have noticed as it was built. I'll take a closer look to see if there is a way to adjust it later this week when it's warmer and there's more daylight but if anyone knows how to do it and could save me some time and frustration I would be very greatful!
Old 04-03-2016, 08:35 PM   #277
Who Dares, Wins
doc73's Avatar
How level were you? These things are light weight and very flexible. If I am way out of level my side doors will stick a bit.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 04-03-2016, 10:17 PM   #278
ChipBruce's Avatar
I agree with doc73, check your level. Mine is slightly off kilter and the door is hard to open because of it.
Sent from my Nexus 7 using Tapatalk
Chip Bruce, RPh
Kansas City, MO
ChipBruce is offline   Reply With Quote
Old 04-04-2016, 12:54 PM   #279
Did you have your stabilizer jacks down? If so, try the door without having them down. I had a Hybrid and noticed if I did not put the stabilizers down evenly the door ends would not line up properly. You might be having the same issue, worth a shot.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
Old 04-04-2016, 03:19 PM   #280
Retired Techie
The seal sticks if not used for a couple weeks. Tried wd40. Not much help. I see daylight in different spots through the seal but never had a leak or metal on metal. Do have a gouge in the door lip from this morning when I bottomed out. Pre coffee loading ended with head up posterior.
2005 Wolf Pack WP22-2016 Grey Wolf 26RR-Gone
2004 Siverado 2500HD Duramax
2013 Keystone Springdale 5r
1998 Honda Valkerie
2016 Camping 148 days so far
moligney is offline   Reply With Quote
grey wolf
