Old 05-01-2016, 01:48 PM   #291
ChipBruce's Avatar
Qwiktime: be sure both the valves coming out of the water heater are parallel to the pipes and the the valve in the bypass pipe between them is perpendicular. That is the working position. The opossite is for winterizing.
2 pics: 1 bypassed one not.
Chip Bruce, RPh
Kansas City, MO
ChipBruce is online now   Reply With Quote
Old 05-01-2016, 01:53 PM   #292
ChipBruce's Avatar
Actually my bad. Here is a correct picture that explains both. Sorry for confusion.
Chip Bruce, RPh
Kansas City, MO
Old 05-01-2016, 03:29 PM   #293
Qwiktime's Avatar
Thanks that's what I was looking for.
2002 Avalanche, 2008 Suzuki, M109R, 1979 Malibu, 2016 Grey Wolf 27RR too many toy's not enough time!
Qwiktime is offline   Reply With Quote
Old 05-13-2016, 01:04 PM   #294
I pick up my 27RR tomorrow and am planning on taking it on it's first trip memorial day weekend. I'm getting nervous about tongue weight. I've seen a few people on this thread that put a rzr in the back of their 27rr and I'm wondering if you have any issues. the claimed tongue weight is about 900lbs but if i put a 1000lb rzr behind the axle, wouldn't that leave me with no weight on the tongue? Anyone putting the same or more weight in the back please chime in with some weights if you know them.
2015 Ram 1500 Crew Cab Hemi 8 speed 4x4 3.92 Gears
2016 Grey Wolf 27RR Limited
2014 Polaris RZR 800
JoshHockey95 is offline   Reply With Quote
Old 05-13-2016, 01:13 PM   #295
Toby's Avatar
You wouldn't drop the tongue weight the same. The trailer axles would handle much of it. It will drop a little though. I don't even need to change my wdh when I load my goldwing in which is almost that heavy.
2012 Ford F-150 EB 3.73
2015 Forest River 25RR
2004 Honda GL1800
Toby is offline   Reply With Quote
Old 05-13-2016, 01:15 PM   #296
Ok I was hoping since the axles look to be more than half way back the trailer that I wouldn't effect it that much. I'll probably have to take it across a scale loaded and unloaded just for fun.
Old 05-13-2016, 03:35 PM   #297
Retired Techie
My Valkyrie at 900 lb I loaded with front wheel between the axles to take some weight off the tongue. I was towing 6800 with 700 lb tongue weight.
2005 Wolf Pack WP22-2016 Grey Wolf 26RR-Gone
2004 Siverado 2500HD Duramax
2013 Keystone Springdale 5r
1998 Honda Valkerie
2016 Camping 148 days so far
moligney is offline   Reply With Quote
Old 05-13-2016, 08:38 PM   #298
What I did....2014 extended cab f250 lariat diesel...full fuel tank...parked on concrete street...put duct tape reference markers on ground uder front bumper and hitch....recorded elevation...put trailer on hitch ball (full water tanks in trailer)...truck measurements front and back again plus rear of trailer and at tandem trailer wheel wells....then I put both Harleys and 200 lb gen set in garage and recorded all elevations again.....then drove the whole rig to public scales n didtruck axels ect.....Very important for you to know the ELEVATION CHANGES AND WEIGHT TRANSFER ELEVATION CHANGES THROUGH THE WHOLE CYCLE....and to then match with scale weights.....on March 21 2016....with no bikes in trailer...wife and I and the whole rig were blown off 95 by big wind just outside Fallon Nevada..every thing destroyed..5 weeks in Reno Nevadas Renoun hosp and rehab..not fun...drive safe...bruce.....neck surgery next week....new king ranch ford in two weeks...toy hauler in a month....and hope this time to get to fish steelhead rogue river Oregon....wife says no more highway 95
9((
juice5 is offline   Reply With Quote
Old 05-14-2016, 07:14 AM   #299
Welcome JoshHockey95, much to my surprise, the tongue weight remains right around 900 pounds with my Harley Ultra loaded and about 910 with out. I do have a Blue Ox WDH which helps as well. I also tow with a 2011 Ram 1500 quad cab, the first long trip I took last October with the HD in the garage, fridge and freezer full, half a tank of fresh water, some black water, the truck squatted a little to much and when I hit a couple dips on the highway, it would bounce for a half mile before it settled down ( I am thinking about installing airbags), that should solve that problem. Enjoy our 27RR, I sure enjoy mine, getting set up this weekend to go Memorial Weekend.
2015 Grey Wolf 27RR Limited
2011 Dodge Ram 1500 5.7L Hemi
2011 H-D Ultra Classic
BKM1066 is offline   Reply With Quote
Old 05-14-2016, 09:11 AM   #300
Usually Confused Member
emm-dee's Avatar
The air thingys will be the best $85 you can spend on towing upgrades. Simple installation. They only actually lift the truck less than 2 inches. Lateral stability is a big improvement.
They do not increase max vehicle weight, but who cares because you're probably so close to max rear axle weight it doesn't matter.
The wireless compressor system is really nice but does cost about $290 or so.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
grey wolf
« Pimp my 26rr | - »
