Old 05-14-2016, 02:15 PM   #301
Just picked up and towed the trailer home today through the mountains in a rain storm with high winds coming across mountain tops. Did ok but was squatting the rear end pretty good. The dealership said that I don't need to use my air bags (AirLift 1000) with the equalizer hitch but I am going to. It bounces too much when I hit bumps and sits a little too low in the rear, although the rzr should help out some too. Truck had no problem pulling or stopping the trailer and held good down 8 percent grade in 5th gear, didn't even touch brakes
2015 Ram 1500 Crew Cab Hemi 8 speed 4x4 3.92 Gears
2016 Grey Wolf 27RR Limited
2014 Polaris RZR 800
JoshHockey95 is offline   Reply With Quote
Old 05-14-2016, 03:43 PM   #302
Usually Confused Member
emm-dee's Avatar
I talked to Equal-I-zer and Blue Ox and both said to set the Airlift bags to 35 psi before before setting up the hitch.
Old 05-14-2016, 05:38 PM   #303
Thanks that's what I was wondering what the proper way to set it up is, since I'm likely going to re set it up with my rzr in it. I'm not sure they set it up properly anyhow, because my truck was squatted more than I would think it should be.
Old 05-16-2016, 07:45 AM   #304
Toby's Avatar
You should check into adding a leaf spring. It's much cheaper and stiffens things up nicely. It worked great for my trailer.
2012 Ford F-150 EB 3.73
2015 Forest River 25RR
2004 Honda GL1800
Toby is offline   Reply With Quote
Old 05-16-2016, 03:36 PM   #305
ChipBruce, snow has melted and am working on my to do list for camping, back to the roll up screen door, I have the screen and channel, now my question is, what are we screwing into? Is it metal or wood?
2015 Grey Wolf 27RR Limited
2011 Dodge Ram 1500 5.7L Hemi
2011 H-D Ultra Classic
BKM1066 is offline   Reply With Quote
Old 05-16-2016, 06:10 PM   #306
ChipBruce's Avatar
Wood. I used short dry wall screws. It hasn't budged! Won't either! Good luck. I put the screen in the channel on the ground and then hung as one piece. Easy-peasy, as my grand daughter says.
Sent from my Nexus 7 using Tapatalk
Chip Bruce, RPh
Kansas City, MO
ChipBruce is offline   Reply With Quote
Old 05-16-2016, 07:54 PM   #307
Thanks, just finished finished installing, very easy.
Old 05-17-2016, 08:44 AM   #308
27RR tires
Just an update from earlier post, I upgraded the tires 14 inch to
15 inch D load and everything worked fine as it turns out there is more than enough room for the larger tires, could have gone to 16 inch.
Just though I would post what I found out.
jertourrider is offline   Reply With Quote
Old 05-18-2016, 08:59 AM   #309
Thanks for the update on tire load range and stepping up to a 15" rim. i am going to go that route as my can am commander 1000 puts me right at the load limits of the tire and a little breathing room will be nice. I load up the machine in backwards and that seems to help with weight distribution. its a 2016 27rr built in feb "16". Using a 2006 Ram 2500 CTD to pull it. Such a great camper, we love it. Its our first and it works out well for my two young sons (6 months, and 2 years) and wife. So far we have used it twice out at big scrub campground in ocala national forest and no issues at all. Great machine! Glad i found this thread/ forum!
Waveslider330 is offline   Reply With Quote
Old 05-18-2016, 01:07 PM   #310
RiderBloke
RiderBloke's Avatar
That's a good idea. What rims and from where and what tires, and just to be more nosey, what prices did the rims and tires run? If they fit a 27RR they will fit a 26RR I believe.
Retired Intentional Interim Minister
Member of the BMW MOA
Saginaw Valley BMW Riders
RiderBloke is offline   Reply With Quote
grey wolf
