Old 05-23-2016, 12:19 AM   #311
Originally Posted by Toby View Post
You should check into adding a leaf spring. It's much cheaper and stiffens things up nicely. It worked great for my trailer.
The new ram's have coil springs so this isn't an option for me, i could have gotten a heavier coil spring but I prefer the air so when I'm not towing i let the air out and the truck rides like a car again
2015 Ram 1500 Crew Cab Hemi 8 speed 4x4 3.92 Gears
2016 Grey Wolf 27RR Limited
2014 Polaris RZR 800
JoshHockey95 is offline   Reply With Quote
Old 05-23-2016, 10:01 AM   #312
Toby's Avatar
Didnt see that coming. Rats.
2012 Ford F-150 EB 3.73
2015 Forest River 25RR
2004 Honda GL1800
Toby is offline   Reply With Quote
Old 05-23-2016, 08:48 PM   #313
27rr tires
The tires are towmax and the rims are dexter, bought from an rv parts
dealer in west central Indiana. He kept the five old tires ( little over one
year old) and i got six new tires all were spin balanced. And he installed
them for about 525.00 total.
Hope that answered your questions.
jertourrider is offline   Reply With Quote
Old 05-23-2016, 10:10 PM   #314
RiderBloke
RiderBloke's Avatar
Thanks, that is helpful.
Sent from my iPad using Tapatalk
Retired Intentional Interim Minister
Member of the BMW MOA
Saginaw Valley BMW Riders
RiderBloke is offline   Reply With Quote
Old 06-04-2016, 08:14 AM   #315
Anyone with the electric leveling jacks having issues with them? When mine are down they don't seem to stabilize the trailer very well. I have tried putting blocks under them so they don't go down as far and it doesn't seem to help. Do the power jacks just not work as well as the manuals?
Old 06-04-2016, 09:25 AM   #316
rmac04401's Avatar
I would say yes they don't work as well.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2002 F150 5.4L extended cab 6.5 bed
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 06-04-2016, 02:07 PM   #317
Make sure the wheels are chocked? I push mine against them while TV is hooked up then put the other set in front - this keeps it nice and tight.
Or you can buy these...
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 06-05-2016, 09:41 AM   #318
I have the x chocks. It doesn't move at all front to front. Side to Side is a joke, it moves as much with the jacks down as it does with them up.
Old 06-05-2016, 11:07 AM   #319
I use wood also under mine vs rubber pads and it seems to help, maybe you could use a couple more jacks under frame. I may consider these later on. Several neighbors when I was camping last year used these.
2006 Honda Goldwing
Old 06-05-2016, 12:54 PM   #320
Usually Confused Member
emm-dee's Avatar
I added scissor jacks in front of the forward axle and with all six down I don't feel any movement at all. My toyhauler is similar in size to the 27RR but about 2,000 pounds heavier. Not sure if that extra weight helps. B
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
grey wolf
