Old 06-06-2016, 10:32 PM   #321
I don't have a problem using other jacks, but I wish I hadn't paid more for jacks that work worse
2015 Ram 1500 Crew Cab Hemi 8 speed 4x4 3.92 Gears
2016 Grey Wolf 27RR Limited
2014 Polaris RZR 800
JoshHockey95 is offline   Reply With Quote
Old 06-19-2016, 11:10 AM   #322
I had Airlift1000 air bags installed, will be camping the weekend of the 24th so will get to try them out and see if that helps. I also installed by rear table in back using eye bolts and ratchet straps, cushions fit perfectly between wall and table.
2015 Grey Wolf 27RR Limited
2011 Dodge Ram 1500 5.7L Hemi
2011 H-D Ultra Classic
BKM1066 is offline   Reply With Quote
Old 06-27-2016, 08:06 AM   #323
Update on the Airlift 1000, what a big difference, no bouncing and no squatting, truck actually rides slightly higher then front now, I could let some air out to get an even ride, will try that next trip. Well worth the it!
Old 06-28-2016, 09:18 AM   #324
Usually Confused Member
emm-dee's Avatar
Yep, big improvement. Did you get the wireless compressor system with it?
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 06-28-2016, 09:48 AM   #325
No, I went with the basic system.
Old 06-28-2016, 12:00 PM   #326
Who Dares, Wins
doc73's Avatar
I loved my airlift 1000. I might do it in this truck at some point. I do not need it for the weight control but I do agree it seems to smooth out some of the bumps along the roads. I never did the compressors.. To me it is a novelty for a few trips. It can sit and tweek the thing up and down until one day I am bored and leave it where it is set never touching it again. I just aired up to 30psi before the trip and left it alone.
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 06-29-2016, 09:46 PM   #327
slide topper 27rr
Has anyone installed a slide topper on there 27 rr, I have a 2015 that I
am going to put one on sometime soon. If so does anyone have
pictures of the rail and mounting brackets where they are mounted.
don't want to make a mistake. Thanks for your help.
jertourrider is offline   Reply With Quote
Old 06-29-2016, 10:25 PM   #328
emm-dee's Avatar
I put in the wireless system but not really worth the few hundred bucks. I only use two settings...35 psi for towing and 10 psi for normal driving. I know that 5 psi is recommended for everyday use but using 10 prevents "wheel-hopping" if I get frisky with the gas pedal.
I also notice the compressor does its thing (either add or release air) sometimes when there is an aggressive outside temperature change. I have it set for 35 early in the morning and when I turn on the ignition later when the OAT has increased about 30 degrees I hear the air release hissing sound. Other times I'll hear the compressor run...usually only 2-3 seconds. I don't know how much pressure is being released/added but because of the very short operation time I believe it is a very small number.
Old 07-09-2016, 10:00 PM   #329
Anyone have any issues with the shower? I see there is no plastic shell on the walls leaving the water to hit the bare luan. And is there anyway to convert the shower to a glass enclosure. I'm a freak about water on campers as I don't want to have a rotted out floor
drb1984 is offline   Reply With Quote
Old 07-09-2016, 11:05 PM   #330
Who Dares, Wins
doc73's Avatar
I have had no issues in 2 years of hard use. I did reseak the seam real well since fr did not. But all good so far.
Sent from my SM-G930V using Tapatalk
2015 ChevyHD D-Max
2014 Greywolf 26DBH
grey wolf
