01-19-2017, 10:30 PM
#401
Originally Posted by Qwiktime
The bad thing is i wanted to put a articulating mount up but I worry about the wall I don't have a space on the backside it's the shower on the other side of the wall and I don't know where the wires run in it i wish I had a wall schematic.
Sent from my SM-G935V using Forest River Forums mobile app
You could find the wall studs and cut piece of 1/2 in or 3/4 plywood and span the studs drill board into studs then bolt mount to plywood. The board will be hid by tv. The widest board would be is 17"
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
01-20-2017, 06:47 AM
#402
I think I might of worked out a folding wood sofa out on the edge of the bed without using the bed just need to measure out somethings.
2002 Avalanche, 2008 Suzuki, M109R, 1979 Malibu, 2016 Grey Wolf 27RR too many toy's not enough time!
01-20-2017, 06:50 AM
#403
You could buy some big joe beanbag chairs. $30 Walmart. Just store in your garage when not using. Bought one for daughter for Christmas.
2005 Honda VTX 1300
01-20-2017, 07:09 AM
#404
I have the idea now put it to wood and we will see.
01-20-2017, 07:10 AM
#405
01-20-2017, 07:17 AM
#406
That's a great concept. Take pictures or video when done.
2005 Honda VTX 1300
01-20-2017, 07:18 AM
#407
01-20-2017, 07:28 AM
#408
Nice thing is it will be removable and if you have drawers you could still remove to get to them and store this flat when done or ready for bed.
01-21-2017, 08:11 PM
#409
I've got the 2017 model and I'm not a fan of the white scare light and the rear ramp light on at the same time. I ordered a three position switch panel to separate them so I don't have the ramp light on all the time. The third switch might be used for a yellow scare light later on. Don't really like the location of the scare light way up in the front of the rig anyway.
Matt & Kathie
2022 Cedar Creek
02-16-2017, 12:10 PM
#410
27rr
I have a 2007 Silverado 1/2 ton that I tow a grey wolf 27rr loaded with a Harley softail classic in back, truck has a 5.3 engine and it tows it great my last camper was a kz26p toy hauler which was much heavier and it towed that fine I did however add air bags to the rear of the truck which I purchased from amazon it was a quick and easy install took me about 30 minutes no drilling needed to install. I try to put things like grills chairs etc in the truck bed to spread out the weight out the weight. I also added the strapless tie down system for my bike it's called the biker bar check out there site it works great. hope this helps answer some questions.
02-16-2017, 12:13 PM
#411
02-16-2017, 01:37 PM
#412
What Air bags did you end up with? I am currently looking on Amazon.
02-20-2017, 10:12 AM
#413
Seriously considering the 27 RR but I'm having trouble finding what the with of the cargo area is between the couches when fold up. I will be hauled a side car motorcycle and it is about 65 inches wide. Will it fit thanks guys
02-20-2017, 10:19 AM
#414
The ramp door width will be your limiting factor. It is more narrow than the space between the folded up bench seats.
02-20-2017, 10:52 AM
#415
The 2017 27rr ramp is larger than 2016. I don't know exact measurements but I'm confident it would fit bike with sidecar.
2016 Grey Wolf 26RR
2015 Ford F150
2015 Harley Davidson Softail Slim
2012 Honda CBR 250
SGT US Army 1985-1990
02-20-2017, 01:39 PM
#416
02-20-2017, 07:33 PM
#417
airide brand from amazon.
02-20-2017, 07:35 PM
#418
2017 27rr rear door width is 70wide by 74.5 high.
02-20-2017, 09:39 PM
#419
No it's not. It's the entire back. Just under 8' x 10'.
2016 Grey Wolf 26RR
2015 Ford F150
2012 Honda CBR 250
02-20-2017, 10:24 PM
#420
Something doesn't seem right here. I can see the "just under" 8' width but not how it can be 10' tall. All the specs for the 27RR show an overall height of 10' 6". Subtracting the height of the AC (maybe 8-10") and the distance ground to floor of at least 18", that only leaves about about 8 feet or less for the ramp door height. The FR website shows the door is 90" x 75".
What am I missing here?
BIRDS AREN’T REAL
