09-18-2015, 01:37 PM
Anyone else here with a Vengeance 25V?
Picked it up Friday week and too a quick shakedown cruise to a local state park.
Had long list of things to buy, by the time we got back home.
The first being a power front jack..... Once u get everything in it it gets heavy!
Mel
09-18-2015, 08:18 PM
You would think a new camper would come with one. I bought one for my last camper off amazon
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
09-19-2015, 08:54 PM
I have the 19v. The inside is very similar.Definitely add the power jack. It makes a world of difference. Enjoy!!
09-19-2015, 10:49 PM
My 2013 25v had a power jack
09-21-2015, 08:53 AM
Vengeance Owner
I have the 2015 29v and the 2500lb power jack broke during the inspection. They didn't have a replacement so they put a different brand 3500lb on it. I have noticed that it has started to bend the leg when I don't put the scissor jacks down and use it in my driveway.
With everything you need in the Vengeance, it gets heavy. I did notice that if I put more weight in the cargo area it tows much better. Makes sense since they are designed to tow full dresser bikes.
2015 FR 29V Vengeance Toy Hauler
2015 Honda GL1800 F6B
2009 Dodge Ram 1500, Total Load Control air bags, Blue Ox Swaypro.
Technology presumes there's just one right way to do things and there never is.
09-21-2015, 11:12 AM
Jet.com has a 3500lb Jack for $99 that I'm thinking about ordering.
Joy & Mel
2022 XLR Nitro 351
2022 Ram 3500HD MegaCab BigHorn 4x4 6.7L
2020 Indian Roadmaster
09-23-2015, 04:42 PM
I added a power jack to my 25v ... it's the best thing I could have done ... that hand jack sux
2006 Dodge Ram 2500 HD - 5.9 Cummings
Equalizer Hitch
2015 Vengeance 25V
2008 FXD with a Lehman trike kit
09-25-2015, 09:53 AM
Don't buy a cheap one!
You can get one online for around $150 but I have heard they fail quite often.
Check out the reviews on Amazon and Campingworld.com
Buy wherever you want but investigate the reviews and get one with a higher rating than you think you need.
Steve...
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
09-25-2015, 10:00 AM
Frog-Toberfest Organizer
I have a vengeance but it's the fifth wheel version. It's a 320A SS
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
09-25-2015, 08:51 PM
Does anyone know where the the valve to dump the fresh water tank on a 25V is? The RV place I bought mine at doesn't seem to
Equalizer Hitch
2015 Vengeance 25V
09-26-2015, 07:04 AM
Retired Techie
Probably between the axles on the drivers side about 2 ft in
2005 Wolf Pack WP22
2016 Grey Wolf 26RR-Traded in
2004 Siverado 2500HD Duramax Sold w225,000
2013 Keystone Springdale 5r Sold
1998 Honda Valkerie Sld
2016 Camping 148 days so far Bought park model and moved to Florida.
09-26-2015, 07:42 AM
On mine there there are two valves, one hot one cold, half way between the hot water heater and the docking station on the drivers side.
Mel
Joy & Mel
2022 XLR Nitro 351
09-26-2015, 07:44 AM
Also, if any of you new owners are having trouble getting hot water to come out. You will have to go under the bed and close the bypass valve and open the hot water valve.
They come from the factory in winterized mode.
I somehow missed this on the walk thru.
Mel
Joy & Mel
2022 XLR Nitro 351
09-26-2015, 08:39 AM
Retired Techie
Actually most new units have three drains. Hot (red), Cold (Blue) low point drains near hot water heater and a freshwater tank drain on the bottom of freshwater tank which usually is located over the axles.
2005 Wolf Pack WP22
09-26-2015, 09:12 AM
Georgia Rally Coordinator
Now that's scary. What else do they not know. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
09-26-2015, 01:12 PM
I don't have the 25v but you are looking for a down spout with a gray cap on it. Should only be hand tight.
2016 Vengeance 320A
09-26-2015, 09:04 PM
Thanks all ... I'll look tomorrow
Equalizer Hitch
2015 Vengeance 25V
09-29-2015, 07:51 PM
Found it ... red and blue ones are between the water heater and the docking station the grey capped drain is about 2 foot inside that further under the trailer ... thanks for the help
Equalizer Hitch
2015 Vengeance 25V
10-08-2015, 11:44 AM
My fresh water drain is an end cap on a line run under the trailer. Look under near where your water tank is, most likely you will have the same setup. This is different than the 2 low point drain lines.
Steve
Golden CO
92 GMC K2500 454
10-31-2015, 07:48 AM
Pick up our 25V next week....
