06-04-2012, 07:03 AM
Auto/continuous setting for ac?
I have only been out twice in my new 21rr. The first time the ac would cycle off and on when it reached the set temperature. This last camping session it never shut off. It seemed to cool ok though. I don't see any place on the thermostat to set the fan to run continuously or auto. Is there a switch for this?
06-04-2012, 07:15 AM
It is always better to take pictures of your problem to get decent advice.
06-04-2012, 07:49 AM
Depending on your thermostat you have an "on" setting and an "auto" setting for the fan.
06-05-2012, 08:41 AM
Here is a pic of my thermostat and I can't see any on/auto setting.
06-05-2012, 06:40 PM
If you press the on/off once that should light up the LED next to fan. Then, by pressing the + and - buttons you should cycle through 'auto', 'low', and 'high' as displayed in the centre screen.
If you can't wake up with a smile on your face, go to bed with a coat hanger in your mouth!!
2005 Ford F150 5.4
2011 Salem 21FBS
06-08-2012, 07:55 AM
I knew someone out there could help, thanks much!
07-24-2012, 05:37 AM
wonder why my 25rr doesn't have thermostat, wish it did. Was this an add on?
2010 GMC SIERRA
2012 GREY WOLF 25RR
2012 campouts: 42
2013 campouts:1
07-24-2012, 08:20 AM
Isn't the fan and A/C two different settings?? On our 325RES, the A/C runs a fan continuously without a fan choice. If you set it to fan, then the A/C isn't running. Maybe I'm missing something??? We did just recently purchase.
Jay & Jill
Kyla (6yr old grandaughter)
Sam (13yr old Lab) Khloe (5yr old Shorkie)
2012 Crusader 325RES
2009 F350
07-24-2012, 09:30 AM
When the fan is set in auto, the fan only runs when the A/C is running...when the temperature setpoint is reached, both fan and A/C shut down. If the fan is set to on position (hi or low), the fan runs continously even after the temperature setpoint is reached and the A/C shuts down. I usually set the fan to run continously to help with circulation. Same as with your home system.
Dave
07-24-2012, 10:40 AM
Really?! Learn something new every day! I'm going to have to play with this! Thanks!
Jay & Jill
2009 F350
07-24-2012, 11:02 AM
You don't have to "play" with it, just read the small Dometic manual for the digital thermostat that you should have received with your trailer. If you didn't get one, you can find the manual on the Dometic webiste.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
09-19-2012, 08:49 AM
Frog-Toberfest Organizer
My 21RR didn't come with a thermostat either for the air conditioner. I was wondering if one could be added. Any help?
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
09-22-2012, 07:58 PM
My 19WP also does not come with a t-stat. It just runs constant. Called the dealer, they said they could modify it to run off t-stat for the low, low, discount price of $700.
2011 Wolf Pack 19DFWP
