Old 06-21-2013, 06:43 PM   #1
Awning relocate? 27' Wolf Pack
For some reason, the awning on our 2011 27DFWP is installed in a position that does not allow the door to be opened fully with the awning open and lower struts clamped. Anyone know how feasible it would be move the entire awning 12" forward to eliminate interference? There must have been a reason why they put it where they did, but I can't for the life of me think of what it might be . Searching Web pics, it looks like the 27' had its awning placed there until the 2014 model which now appears to be in a better spot.
The entire track would have to be moved, which has been sealed in place. How much of a mess am I going to make by trying to move it?
Ideas?
ulaing is offline   Reply With Quote
Old 06-21-2013, 07:26 PM   #2
Ideas?
Pictures please. You can buy the rail separately and just add on to the existing one. You can also buy a specially made roller to put on the door.
Old 06-21-2013, 08:03 PM   #3
Great idea Oldcoot...I hadn't thought of simply adding extra track. This would also make it easier to install a larger awning in the future if desired. I'm just a little concerned about the support from a small piece rather than the entire length? Would it be sufficient?
Pic attached.
Old 06-21-2013, 08:09 PM   #4
Pic attached.
Simple solution, unhook the support and stake it down on the ground and tie the awning down. Save a lot of trouble.
BTW, that's what we have to do with the power awnings when the wind comes up a little.
Old 06-21-2013, 08:16 PM   #5
Haha yeah I knew someone would say that
And yes we often set it up that way, but there are times when it is more convenient to leave it clamped to the trailer...
Old 06-21-2013, 08:22 PM   #6
Next question, why do you want the door any farther open? I would definitely put a roller on the door to keep the door edge from rubbing on the awning.
Old 06-21-2013, 08:37 PM   #7
It would be nice to be able to utilize the catch when only using screen door. The door already has minor damage from banging against the strut (guests, kids, wind....). right now we have to use bungee cord.
The roller is probably a good idea, although we haven't really had any issues with the door rubbing on the awning. Thanks for the suggestions!
Old 06-21-2013, 08:51 PM   #8
Put a pool noodle on the strut and continue to use the bungees. Much easier and simpler.
