Old 07-10-2016, 10:31 AM   #1
Battery issue
I am currently at a race with our 27RR with no hook ups. I have two deep cycle batteries and have been using the trailer since March with no issues.
Arrived two nights ago and used all battery power with the exception of using the generator a few times for the microwave.
Ran the ceiling vent almost continuously and after 24 hours the lights were dimming and panel showed batteries almost dead. Ran the generator for a few hours but as soon as I turned it off batteries were completely dead.
Being we are at the race I don't have a meter to check anything. All fuses look good. The new batteries had run dead last week but brought them up with shore power.
Anything else I can check? Where is the inverter located on my unit?
Thanks in advance.
jrminiquad is offline   Reply With Quote
Old 07-10-2016, 10:44 AM   #2
Charging off a generator will require a better charger than the convertor that is built in can do. A high amp quick charge battery charger is in need.
2015 Forest River Grey Wolf..Traded
2015 Forest River Cherokee 274RK
2001 2500hd
2014 Jeep SRT...did not trade
Simplewon is offline   Reply With Quote
Old 07-10-2016, 08:23 PM   #3
Back home now. Continued to run generator today, did not charge batteries whatsoever.
Items run off of DC were not working when plugged into tow vehicle. Plugged into shore power at home for a few hours, when unplugged DC items would not work either.
Interestingly enough, electric jack worked just fine, so batteries must be charged but no inside will work off battery.
Any ideas?
Old 07-10-2016, 08:28 PM   #4
Flybob's Avatar
Check the two high current fuses (30-40) in the converter and the resettable breaker on the frame near the front
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-10-2016, 08:53 PM   #5
Any idea where the converter is located?
Old 07-10-2016, 09:00 PM   #6
Retired Techie
Jack is wired direct so battery is up. Check resettable fuse on A frame. Also fuses on power panel
2005 Wolf Pack WP22-2016 Grey Wolf 26RR-Gone
2004 Siverado 2500HD Duramax
2013 Keystone Springdale 5r
1998 Honda Valkerie
2016 Camping 148 days so far
moligney is offline   Reply With Quote
Old 07-10-2016, 09:43 PM   #7
Who Dares, Wins
doc73's Avatar
My power was out (a 26DBH) a few weeks ago. The breaker (under the am frame) had tripped and caused the same results you had.. Power when plugged into house or truck. Nothing on battery. A push of the little tiny plastic detent and I was in service.
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is online now   Reply With Quote
Old 07-10-2016, 10:51 PM   #8
northstar1960's Avatar
X3 on the breaker under the a frame , just track the positive off the battery to it
northstar1960 is offline   Reply With Quote
Old 07-11-2016, 05:50 PM   #9
I'm really striking out here. Can't find any type of breaker under the A-frame. I have a junction box, but when opened is only spliced wires.
Checked all 15 amp fuses again, and two 40 amp and all is good. I must be missing something obvious.
Here's what I got;
Old 07-11-2016, 06:35 PM   #10
Jimandchris's Avatar
Look closely at your pic, at the breaker where the wires come together. There's a small black button you may need to push in. I can see it when I zoom in where back and red wire is connected.
Edit. Meant black wire.
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
battery
