Old 05-27-2016, 05:07 AM   #1
Battery not working on wolf pup toy hauler
Our battery only runs a few things like the radio when we aren't plugged in to a generator, but suddenly it's not working at all. We checked and it is fully charged, and the items work fine when we are plugged in so we don't think it's a fuse or breaker problem. Is there some battery cutoff we may have accidentally engaged? If not what could this be?
franco928 is offline   Reply With Quote
Old 05-27-2016, 12:40 PM   #2
Head Rambler
It's most likely a breaker near the battery. They're usually located on the frame near the tongue members.
Gotta go campin!
Old 05-28-2016, 09:06 AM   #3
Didn't see anything like that but now it's suddenly fine. Thanks!
Old 05-28-2016, 09:12 AM   #4
Pickin' & Campin'
Sounds like you have a poor connection somewhere.
You are going to have to trace the battery wiring from the battery to the distribution panel to determine the cause.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 05-28-2016, 12:26 PM   #5
Re-set circuit breaker
I have a 2014 Wolf Pup toy hauler. It had an automatic reset breaker at the rear of the frame rail just behind the tongue and next to a connection box containing wiring from the tow vehicle and some other stuff (I can't remember). I moved mine as it was too exposed to the elements, but I redesigned the whole set up. The chassis ground is right there also.
NatlChamp is offline   Reply With Quote
battery, toy hauler
