Old 12-02-2014, 09:53 AM   #11
KMP44's Avatar
These guys offer engineer stamped plans. You just choose it in the custom quote section as an option. I would think most lumber yards that sell pole barn packages have an engineer they work with or can recommend to review & stamp their plans.
DIY Pole Barns - Pole Barn Kits, Pole Buildings, Packages, Builders, Prices, Plans
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 12-06-2014, 03:51 PM   #12
trbomax's Avatar
I think when it gets closer to spring thaw I'm going to check them out.Didnt really want full walls but it would really stiffen up the structure.
trbomax is offline   Reply With Quote
Old 12-06-2014, 05:34 PM   #13
Try AllSteel Carports. Headquarters is in Muncie, IN and I know they do jobs in Michigan. Just had them put up a 18x40 with 12' walls. They'll do 16' walls in IN but it got to be more $$ than I wanted to spend. Had mine fully enclosed back and sides. Plan to build out swinging doors this spring. That will give me plenty of height for what I need now and for the next couple of upgrades. Couple of photos are attached. If you have questions or want more info let me know. Good luck!!!
ID:	67218   Click image for larger version
Brian, Stacy, and the girls (11 and 8)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 12-06-2014, 05:52 PM   #14
Jay Pat's Avatar
Here is a choice.
Versa tube steel framed building
Jay Pat is offline   Reply With Quote
Old 12-06-2014, 05:57 PM   #15
mattb's Avatar
Two years ago we had our 30X40 barn built with these steel trusses, came with eng. drawings. 16' max between trusses and will allow for a shorter wall in relation to internal height. My barn has two internal trusses. Standard wood construction front and back walls. Total cost w/crete under $20k. Their website is not as good as it used to be.
Lifespan Building Systems | Garages
Matt
mattb is offline   Reply With Quote
Old 12-06-2014, 06:15 PM   #16
just call it another type of agriculture storage
47chevy is offline   Reply With Quote
Old 12-06-2014, 11:32 PM   #17
Re: Versatube, I looked hard at them. Found their cust svce a little lacking, plus they do not offer installation although their pricing was high enough that it seems like it should. If you can put it up yourself (which is no small task for one this size), I think it'd be a good option. Considering their premium price plus having to pay to have it put up, it was more than we wanted to spend.
ProPride Hitch
Old 12-07-2014, 08:43 AM   #18
Mr. Dan's Avatar
I used T-N-T Carports. They have nationwide (?) installers. They built my RV shed and a tractor shed with a roll-up door. They did a good job for me.
http://tntcarports.com
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 08-12-2015, 07:00 AM   #19
Update on our storage bldg.
After about 10 months, very happy with the AllSteel "carport.". Finally got around to adding power, compressed air, and front doors. Well, front doors are mostly done. Waiting on some help for the upper panels. Some pics below. First is power and air station. Second is door frames built on ground. Third is door frames up with some sheet metal installed. Still need to clean off the metal cutoff blade dust, install trim, install upper panels. Then all set for now.
ID:	85389   Click image for larger version
ID:	85390   Click image for larger version
ProPride Hitch
