Not sure about all the connections you list. Generally, most units have two incoming connections. One is for satellite and the other for cable. Inside the unit, if you have two connections adjacent to each other they are output connections to send signal from the satellite and the cable/antenna. On one of the interior output boxes there should be/is a small push button. Pushing it will turn on an adjacent small indicator light, and if it's on that means the signal from the rooftop antenna is going to the tv connectors. If it's off then you will have cable data going to the same connectors. It's either one or the other..not both at once.
BIRDS AREN’T REAL
