06-19-2016, 04:11 PM
connecting/disconnecting shore power
A general question for the forum, when connecting/disconnecting shore power, is it a good idea to cut the main breaker on the panel?
2018 XLR Hyperlite 29 HFS
2018 RAM 2500 6.4L HEMI
2015 H-D Ultra Triglide
2015 Polaris RZR 570
06-19-2016, 04:12 PM
Who Dares, Wins
I do.
Sent from my SM-G930V using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
06-19-2016, 04:18 PM
Old Camping Squid
I do as well, I think it's better to turn the beakers on one at a time after the main, just my opinion... no facts to back it up.
Larry Collins { PM }
2006 F150 Supercab 5.4 Flex Fuel
2017 H-D FLHTK Ultra Limited
EZgo TXT and ClubCar Precedent golf carts
2009 Forest River Salem 30QBSS
U.S. Navy Veteran
06-19-2016, 04:21 PM
I turn the breaker at the pedestal off prior to plugging in the shore power cord and turn it off before pulling it out when leaving. I also use a good quality surge protector for extra caution.
2015 Rockwood 8329SS TT
2004 Chevy 2500HD D/A 4X4 CC SB
Andersen Weight Distribution hitch
Who Dares, Wins
I reread... I flip off the pedestal not the trailer breaker.
2015 Chevy HD D-Max
06-20-2016, 06:52 AM
The reason for my question is,I have one fuse that seams to blow whenever I connect, disconnect shore power or the battery, it is the top fuse labeled bedroom lights, it runs the bedroom lights, sink light, stove fan and light, two lights in the garage, and the thermostat. I also have a surge protector but for some reason I did not use it when connected at home and we had a power interruption which may have blown the fuse recently. I added a battery disconnect and also plugged in my surge protector. I will be extra cautious when connecting and disconnecting and try your breaker method. Thanks!
06-20-2016, 03:04 PM
If the fuse you said is blowing is only powering the things listed, it shouldn't be blowing unless it's extremely under rated. I'd look for something else that it powers or for something shorted in the circuit.
P.S. It's always a good idea to open (throw) the breaker at the pedestal when connecting and disconnecting the shore power cord.
Gotta go campin!
06-20-2016, 04:12 PM
I hard wired in a surge protector and never have an issue with a surge when plunging in. You should not have to reset breakers - may have bad breakers - they can wear out over time.
Progressive Industries RV Surge and Electrical Protection industry lea
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
06-20-2016, 07:39 PM
Originally Posted by BKM1066
... I have one fuse that seams to blow whenever I connect, disconnect shore power or the battery, it is the top fuse labeled bedroom lights, it runs the bedroom lights, sink light, stove fan and light, two lights in the garage, and the thermostat. I also have a surge protector but for some reason I did not use it when connected at home
Surge protector would do nothing. Depending on its specs, it may ignore anything on 120 VAC until voltage well exceeds 330 volts. Others should have known that. To say more requires spec numbers for that protector.
AC power cord should be constructed so that appropriate hot conductors disconnect before neutral or safety ground. If not, a voltage spike may exist for reasons too complicated to explain. IOW you should never have to first cut off a beaker. Good practice always says everything must have a backup. Do that to avert problems. If that plug and receptacle do not work right, then breaker will provide backup protection. Only so that a problem does not cause a failure.
That procedure is to avert a failure. But never ignore that failure. Find and fix it. Woefully too few facts are provided for a useful answer.
What is provided says (as Bama Rambler also notes) that tripped fuse is a serious problem unrelated to what else is on that circuit. Even power interruptions do not blow fuses. That defect should be addressed. One thing to inspect has been described. Protector would not and does not claim to solve that defect.
06-20-2016, 07:46 PM
We always turn off the breakers before we plug in and before we unplug.
06-20-2016, 08:07 PM
not that it matters cause it really doesn't . most campground pedestals will have the breaker off all ready though not a bad idea to make sure it's off before you plug in but really doesn't matter . you won't screw the pooch if you plug into a live outlet .
06-20-2016, 08:29 PM
Rarely is a campground pedestal breaker off unless the camper before switched it off. But there is sometimes an arc if you hook up / plug in with the breaker on........ ....... but I have done it both ways with no problems ( old age I usually forget to turn the breaker off when plugging up....
Personal recommendation is breaker off.....
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
06-20-2016, 09:10 PM
I've never flipped the main breaker on my house if the power goes out and never turned off a breaker before I plugged anything into a household outlet. What's the difference? (I usually turn off the pedestal as well....just don't think it's necessary )
06-21-2016, 06:37 AM
The difference is that with your home the flash of a reconnect occurs in the power company equipment far away, not in the pedestal next to your hand.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
06-21-2016, 12:11 PM
Plugging in to shore power should not have anything to do with your popping a 12v fuse. FIRST THING is check your ground to the battery, always suspect bad ground first, maybe clean the cable on the battery and where it connects to the frame.
I would then go around and check the connections on all of the components on that circuit. You might have a bad ground or power connection somewhere. They just daisy chain from one end usually, so if you find a bad connection it should fix it. Odds are one of the wires will pull out when you pull the light or whatever you check.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
06-21-2016, 03:46 PM
Never have i pulled into a campground where the breaker was already ON !
everybody has different experiences / . I'm sure you'll now come across many that are off i will will start seeing them all be on
06-27-2016, 07:20 AM
I played around with my wiring issue some more, I believe the short is located in the stove hood fan/light unit. I disconnected the wiring for a while no blown fuse. I reconnected for a while, then disconnected, playing around with the wires, tugging and moving them, no blown fuse, I was getting ready to go camping on Friday, fuse blew. So I left the hood wiring disconnected, replaced fuse (needed the thermostat to work) replaced fuse, it blew again. When I got home from our trip yesturday, I took the entire hood off and inspected the wiring, I was convinced I would find a bare wire some where chafed on a sharp edge, nothing, it all looks good. Going to play around some more today. If I don't find the real problem, I am considering placing the thermostat on its own separate fuse.
08-17-2016, 07:00 AM
I did more troubleshooting and found that the wiring to the light just above the bed is causing to fuse to blow, so disconnected that section of wiring and the fuse has not blown for several weeks. Will work on getting that fixed after the camping season is over. I will say this, I have learned a lot about my camper and also got the opportunity to clean up all of the wood and metal shavings left behind when the camper was built.
08-17-2016, 08:45 AM
The only time I turn off the main breaker in the trailer is if the pedestal
has no breakers. Don't see this often but have come across it several times.
