Old 06-06-2016, 07:48 PM   #11
Glad you made it and have fun. I still owe you a cold beverage for the help you gave me on my first trip with our 26rr. Only half hour or so up the road in Vero.
2016 Grey Wolf 26RR
2013 GMC Denali 2500 HD
Vero Beach, FL
Vero Beach, FL
jbeal43 is offline   Reply With Quote
Old 06-06-2016, 08:07 PM   #12
Thank you very much! How's everything with you all? We are coming back June 16th from this trip and go right back out June 22nd for 10 nights in Jacksonville and St Augustine. You all should come!
drb1984 is offline   Reply With Quote
Old 06-07-2016, 08:01 PM   #13
I envy that! I'm only good for long weekend trips unfortunately. Keep us posted on your trip and hopefully all the systems stay perfect. Where you staying in St Augustine? We want to do a long weekend up there.
Vero Beach, FL
Old 06-07-2016, 09:01 PM   #14
northstar1960's Avatar
I've got the HF chock also . Has worked flawless for over 7000 Miles . only need a couple straps up front and a e-track mounted for the rear wheel that just secures the rear wheel to the floor . that's just in case in case
northstar1960 is offline   Reply With Quote
Old 06-07-2016, 09:06 PM   #15
We are staying in anastasia state park
Old 06-07-2016, 09:13 PM   #16
Usually Confused Member
emm-dee's Avatar
You might want to consider a Titan chock. Ride your bike into it and get off. It will not let the bike fall over and only needs minor strap pressure. I only compress the front forks about inch and it's been hauled thousands of miles like that.
https://excel-equipment.com/titan-bu...hock-2073.html
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 06-07-2016, 09:21 PM   #17
Does that need to be bolted through floor?
Old 06-07-2016, 10:03 PM   #18
emm-dee's Avatar
It uses a small (maybe 3x6" or so) steel plate. The chock attaches to that with a single wing nut. Quick and easy to remove. I believe it could also be attached like the pictures above. I've never had a problem with the plate bolted in. If the chock is not there the plate is covered by a swivel rocker.
