Old 05-01-2013, 09:41 PM   #1
Generator
Just ordered a 25RR & was wondering what size generator i need to get?
blevinsbulldog is offline   Reply With Quote
Old 05-01-2013, 09:45 PM   #2
TURBS's Avatar
Get for ???????
A/c ?
Battery charging?
Need more info.
Turbs
Old 05-02-2013, 05:43 AM   #3
Im new to this camper stuff so i guess running the camper when not at a camp ground. A/c included.
Old 05-02-2013, 06:24 AM   #4
TURBS's Avatar
A 1000 defiantly will not run a/c. 8 amps at 120v
A 2000 is also questionable for a/c use I would not recommend this either. 16 amps at 120v
A 3000 IMO is what you need to run a/c minimum. 25 amps at 120v
Old 05-02-2013, 06:36 AM   #5
TURBS's Avatar
Please do a search here on frf "generator" you'll find tons of info.
Also read this.
http://www.forestriverforums.com/for...aws-17300.html
Old 05-02-2013, 09:55 AM   #6
If you have a 13.5 KBTU HVAC, a 2KW is really iffy. The Yamaha 2400 will run a 13.5 and is about the smallest genset that will.
You would do much better with a 3KW or paralleled 2KWs.
If your trailer has 15 KBTU the 3 KWs are ok to iffy, paralleled 2KWs OK.
If you are not concerned with the noise of a contractor grade genset, you can get by with just about any 4KW+ genset. Very cheap.
Foard County News & Sassy Schoolmarm
with Lady & Chloe, 2013 39 days, 2014 59 days
2017 GD Imagine 2800BH
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
ng2951 is offline   Reply With Quote
Old 05-02-2013, 10:31 PM   #7
Dometic makes a 3000 watt generator that is reasonably priced (I paid $800 recently in Canada) and Champion makes a nice 2000 watt unit that is very reasonably priced. Check my
You Tube video for a comparison of my Dometic and a Hyundai 1250 watt unit. Rumour is the Champion 2000 watt Inverter is quieter
Night_Wolf is offline   Reply With Quote
