Old 07-18-2015, 02:31 PM   #1
Generator size
New to RVing, I just bought a new 26RR and am wondering what size generator I need in order to use the microwave, AC, or tv while not plugged in. Can anyone help me with the right size and recommend a good inexpensive one?
mikeroll is offline   Reply With Quote
Old 07-18-2015, 03:15 PM   #2
bikendan's Avatar
What btu is you a/c?
Minimum would be a 3000w inverter generator if you plan on using it in a campground.
For boondocking, any 3000w+ generator should work.
Inexpensive one would not be appropriate for campground usage. Unless a $700 inverter generator would inexpensive to you.
If it's for non campground usage, the Champion 3500w is a very popular choice and can sell for around $300.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-18-2015, 03:31 PM   #3
Georgia Frog Rally 2018
aceinspp's Avatar
A lot depends on the size of your AC to give a good reply. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-18-2015, 04:21 PM   #4
Thanks for the help, I'm totally new at this so I greatly appreciate it. The AC is listed as 13.5 K btu.
Old 07-18-2015, 04:40 PM   #5
aceinspp's Avatar
Just be aware when running on gen that you can not run all appliances at the same time especially a Microwave.(unless you buy a good size Gen 4500w) I have a Gen that puts out 3200w and will run my 15000 BTU AC and nothing else. If running a 13500BTU you can run the air a TV. If using microwave I turn the AC off. Also how quiet do what the Gen to be? Later RJD
Days camped 2017 62
Days camped 2018 18
Old 07-18-2015, 04:43 PM   #6
Blog: RVroadtripper.com
hbillsmith's Avatar
A CHampion 3100 inverter is quiet and can run your A/C and LED TV. Turn off the A/C if you need to run either the microwave or a hair dryer.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 07-18-2015, 05:00 PM   #7
aceinspp's Avatar
My Boliy 3600 is putting out 400w more than a Champion. Constant 3200w. Later RJD
Days camped 2017 62
Days camped 2018 18
Old 07-18-2015, 08:13 PM   #8
Have a 2015 26rr, champion 3500/4000 runs entire unit. I have found that it is best to switch breaker for refridgerator off and run on propane when AC is on. We have used this generator for two years at GNCC races with zero issues. Noise at race track area is not an issue. I bought a 25' extension and put generator near front of truck. I can't complain one bit about the performance of this unit. However, if noise is any issue, look into inverter type of generator. My next choice would be two champion 2000's.
2014 Grey Wolf 25RR, 2012 F150 3.5ecoboost 3:55elocker 4x4 firestone air bags, 2004 HD Fatboy
0488FB is offline   Reply With Quote
Old 07-19-2015, 07:18 AM   #9
I have two Champion 2000 watt inverter generators with the parallel kit. Just as quiet as the Hondas. I can run my 15k AC and fridge with TV's just fine. Have to be careful with the Microwave and AC simultaneously. The Champions with the parallel kit were about 1300 total. Hondas would be over 2000.
Sent from my SM-G920P using Tapatalk
rabreen is offline   Reply With Quote
Old 07-19-2015, 07:24 AM   #10
Left Coast
Mine weren't....just shop around in winter time...lots of sales
generator
