Old 01-07-2016, 04:22 PM   #21
AquaMan's Avatar
My truck connection (GMC DMax with dual alternators) was enough to power the hydraulic landing gear of my 5er when my battery was dead
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-07-2016, 06:24 PM   #22
I was instructed that it is ' Ground Wire Off First " I could be corrected but that has always been my understanding.
kenenn is offline   Reply With Quote
Old 01-08-2016, 03:13 AM   #23
wmtire's Avatar
You are correct, as long as its a negative ground system (the vast majority of things), that's the way it is. Now some vehicles can have a positive ground system, which then makes it all opposite but this is going to be the exception, not the rule.
An RV/travel trailer isn't most likely going to have as much metal near the battery as a vehicle, but it's just a best practice to do it this way to be sure. My propane tanks (which rest on the frame) are in very close proximity to my battery, which I usually remove the propane tank cover to gain more access to the battery box behind it.
Battery and Negative Terminal - How to Disconnect a Battery
How To Remove And Install A Car Or Truck Battery, Cleaning Corroded Terminals
http://www.autoevolution.com/news/ho...tery-1372.html
How to Remove and Install a Car Battery - For Dummies
https://www.pepboys.com/parts/batteries/diy_replacing/
http://www.napaonline.com/KnowHow/battery-service.aspx
This has kind of been a hijack, but I'm thinking the OP was satisfied and had his question answered judging by his response in post #6.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 01-08-2016, 05:26 AM   #24
davel1971's Avatar
Isn't that the case with 99% of the threads on here? I don't think that means we should stop responding. You never know when someone could input some meaningful information on the subject.
David & Lynn
Old 01-08-2016, 04:26 PM   #25
You should keep the battery charged.
dagwood18 is offline   Reply With Quote
