Old 11-09-2015, 03:18 PM   #1
grey wolf 19rr ramp support
hello all, we just purchased a 2012 grey wolf 19rr, it seems to be in almost new condition, including the ramp has never had anything loaded on it, I have read that the door really does not support a lot of weight, our bike is about 800lbs and the door is rated at 1600lbs, I really would like to avoid driving up the ramp and build or buy some kind of ramp system that clears the ramp completely, any ideas???
john_rosie is offline   Reply With Quote
Old 11-09-2015, 03:24 PM   #2
Retired Techie
I have a 26RR. Same ramp. Holds my 900 lb Valkyrie no problem. I extended ramp by 2 ft so I would not bottom out when loading. Just be careful both supports are on the ground equally. You could probably warp it if you were to far out.
2005 Wolf Pack WP22-2016 Grey Wolf 26RR-Gone
2004 Siverado 2500HD Duramax
2013 Keystone Springdale 5r
1998 Honda Valkerie
2016 Camping 148 days so far
moligney is offline   Reply With Quote
Old 11-09-2015, 03:32 PM   #3
how do you extend it also what supports??? I have electric stabilizer jacks but nothing on the door
Old 11-09-2015, 03:50 PM   #4
Retired Techie
There are two rubber bumpers on the top of the outside of ramp that set on the ground to support the ramp while loading. There are pictures on the 26RR section of my ramp extension. It also shows rubbers which I extended 2.5 inches.
1998 Honda Valkerie
Old 11-10-2015, 12:37 PM   #5
I have 2014 27RR...first thing I did when putting the two Harley deluxes into the trailer was to gouge the diamond plate with side stand as it traversed the sill ! So after replacement I put a short length of 2 X 6 in the slot with an 8 inch wide by 20 inch long piece of 12 guage sheet metal screwed to the wood to deflect the sidestand and drilled traction holes in lower sheet metal for ''wet entry'' (I store it in the Trailers Chock Box)....then made a few more for friends with Greywolf RRs....I also run the hitch stand down to raise the front and decrease entry angle...best wishes juice
juice5 is offline   Reply With Quote
Old 11-10-2015, 03:35 PM   #6
Goldwing loading
I have a gray wolf RR19, 2012 also, and have loaded my 1800 Gold wing several times. The door supports the weight OK. My problem was high siding under the mc engine at the door hinge point. I got a arched ramp which hinges in the middle to use for loading, and also jack the front of the trailer way up to load/unload. Gold wing weights about 900 lbs, plus my 240 lbs. Good luck
ShawneeOkie is offline   Reply With Quote
Old 11-11-2015, 12:17 PM   #7
do you have any pictures of the folding ramp? also Juice, do you have a picture of the rig you built ?
Old 11-11-2015, 03:06 PM   #8
Retired Techie
Pics are posted under 26RR ramp extension
1998 Honda Valkerie
Old 11-11-2015, 03:59 PM   #9
Photo of ramp to trailer, in position. Would actually have front jacked up to max. The 2x6 on the ramp are to allow my feet to easly contact the ramp while straddling the bike. Keep bike moving. the green board is loaded in first to support fork and kickstand. (may not be necessary, but gives me peace of mind). Good luck.
https://www.dropbox.com/s/pae0gl12bs...uide2.jpg?dl=0
Old 11-11-2015, 10:00 PM   #10
How do secure the green board to floor of toy hauler?
drb1984 is offline   Reply With Quote
grey wolf
