Old 04-24-2012, 07:23 AM   #21
Quad411, depending on just how much firewood you intend to carry, don't forget that any weight put on the back bumper of the camper decreases the hitch weight. Might not be a problem on yours, but is worth considering.
Old 04-24-2012, 07:36 AM   #22
TURBS's Avatar
Windrider and others.
A few charts.
http://www.towingworld.com/articles/TowingLaws.htm
State Towing Laws for RVs
Very helpful!
Old 04-24-2012, 08:00 AM   #23
Good info, thanks.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-24-2012, 08:04 AM   #24
TURBS's Avatar
Glad I could contribute!
A lot of good info there.
Old 05-21-2012, 07:08 AM   #25
Originally Posted by Quad411 View Post
I have a 2008 27 GTFW wolf pack. I was wondering if anyone out there has put a hitch on the back. If you have, did you find one that went right on, or did you have to have one fabricated?
I used this: Curt Manufacturing 19101 It mounts to the rear bumper. You will need to drill 2 holes through the bumper for the mount bolts. I also used sealant between the bumper and hitch to help against vibration corrosion and to keep it nice and snug. This will work for firewood and bikes, the bumper wont pull a trailer. If your set up is like mine, you wont be able to mount the hitch in the center because of the spare tire and protruding lowering device. It will be offset about a foot or so. Good luck!
Top B is offline   Reply With Quote
Old 05-21-2012, 07:22 AM   #26
I hope the Curt hitch people send along a warning that you can't actually use their hitch without reinforcing how the bumper is attached to the camper frame rails! Put any additional weight on the back "bumper", and it is definitely going to come off, and maybe injure an innocent third party.
DonG is offline   Reply With Quote
Old 05-21-2012, 07:33 AM   #27
Like I said, it will hold a light load like bikes or firewood. I'm not adding hundreds of pounds to the bumper or towing with it. I put the bikes and bike rack on it and jumped on it and it didn't budge. BTW, I'm 6'3" and weigh 270 lbs, so I don't see the bumper falling off.
Old 05-21-2012, 08:24 AM   #28
Herk7769's Avatar
I wish you the best of luck with this hitch. Most will tell you you are making a big mistake, though. Bikes actually do the most damage due to the constant up and down motion as they go down the road. Over time that flexing will break the welds.
ID:	14210   Click image for larger version
ID:	14211   Click image for larger version
ID:	14212   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 05-21-2012, 08:47 AM   #29
Thanks for the info. Top B. I ended up taking it to a local welding shop. He custom fabricated me a hitch that goes around the spare tire, and reinforces back a couple beams for $150.
Piston is offline   Reply With Quote
Old 05-21-2012, 09:12 AM   #30
FreedomTracker's Avatar
I did the same as Piston (below) once to a 20 yr old popup with no problems. However, after reading all the posts against this, I hesitated with my new TT. Ended up putting bikes and firewood in the truck... another good excuse for a new truck.
IMHO, if I were to put a receiver on the back of a TT, it would ONLY be a custom built hitch from a welding shop with lots of experience with hitches and trailers... just my 2 cents.
Good luck, whatever you decide.
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
led pad
