10-15-2017, 04:54 PM
Hot water heater bypass location 26RR
I have been searching for 45 minutes and have not found any information. Is the hot water bypass valves located in the closet under the slanted board in the closet? If not there I don't know how you would access it. Thanks in advance.
10-15-2017, 04:55 PM
What kind of a unit do you have Doug?
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2021 Chevy Silverado 3500HD DRW 4X4 Duramax
“It's not how old you are, it's how you are old.” ― Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
10-15-2017, 04:56 PM
It is the Grey Wolf 26RR. Thanks.
10-15-2017, 05:15 PM
Water heater is located on the left front corner of the trailer. I would think that the by-pass valves are right on the back of the water heater. If that is a closet or a nightstand next to the bed, (left side) I would say that you probably have to remove a panel in the bottom of that closet or nightstand to access the valves.
Good luck.
Mike and Yvonne
10-15-2017, 05:22 PM
You can access by lifting the bed. It is on the left. The fittings are right behind the water heater.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
10-15-2017, 05:23 PM
I removed the Luan piece in the cargo hold to make access easier.
2005 Honda VTX 1300
10-15-2017, 05:24 PM
Thanks a lot for all the help guys. This forum is great!
10-15-2017, 05:26 PM
Can you tell me what the Luan piece is?
10-15-2017, 08:09 PM
If you look through the cargo door you will see a small piece of Luan that shields the water heater from cargo you put in the cargo area.
When you lift your bed you can see into cargo area. To the left you will see the price of Luan and the water heater.
2005 Honda VTX 1300
10-15-2017, 08:16 PM
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
11-09-2017, 06:17 PM
Luan piece
The luan piece is a joke. It's stapled to a piece of one by one on the floor. Anyone pushing things in through the access door on the right side will push it right in. I took mine out (22RR) and fashioned something a little sturdier. But really you just have to be careful adding stuff. I have a easy-up that just fits but pushed the original luan off of it's staples.
