Old 07-03-2018, 08:32 AM   #1
How to raise 26RR to change flat tire
I have searched all over but surprised I can't find any info. Can I use a leveling step to raise one of the axles to changed the other tire or will that do damage to the axle? What is the correct way to raise it to change a flat?
Sent from my SM-G950U using Forest River Forums mobile app
Doug D is offline   Reply With Quote
Old 07-03-2018, 08:37 AM   #2
jd50i's Avatar
I use the jack in my tow vehicle on my 21RR but I have to keep a 4 way lug wrench in the trailer since my trucks lug wrench won't fit the trailers lug nuts.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline   Reply With Quote
Old 07-03-2018, 08:45 AM   #3
Brother Les's Avatar
Google is your friend. You will get many ideas quickly, as there are several different ways. I have a 'tire buddy', but have also used my tow vehicle jack. Sometimes both at the same time.
Situations are different at different places and locations.
Brother Les
Old 07-03-2018, 08:49 AM   #4
Yes you can use leveling blocks to drive up on to raise the other axel. Or if you have leaf-springs you can do what I do. Use a bottle jack like this. Be safe and use jack stands under the frame.
modemem is offline   Reply With Quote
Old 07-03-2018, 01:07 PM   #5
Like modemem says, I use 3 2X6 to drive up on good tire and opposite tire comes off the ground. But loosen lug nuts prior to lifting.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 07-03-2018, 01:35 PM   #6
rlh1957's Avatar
Trailer Aid Tandem Tire Changing Ramp, The Fast and Easy Way To Change A Trailer's Flat Tire, Holds up to 15,000 lbs, 4.5 Inch Lift (Yellow).
Back it up on the good tire or pull forward on the good tire and it is all ready to change.
https://www.amazon.com/dp/B000I4JPZE...v_ov_lig_dp_it
rlh1957 is offline   Reply With Quote
Old 07-03-2018, 06:05 PM   #7
Don Reesor's Avatar
hyway
Hi I had to change two tires on the montreal bridge I made a small ramo with 4 or 5 2x6 and drove the good tire up on it after I loosened the nuts 15 mins easy
Don Reesor is offline   Reply With Quote
tire
