Old 08-13-2015, 08:20 PM   #1
trbomax's Avatar
I guess I shouldnt be surprised......
all 4 sets of brake wires pulled against a crossmember and the frame.$.50 of split conduit would eliminate a possible disaster.
trbomax is offline   Reply With Quote
Old 08-13-2015, 08:40 PM   #2
rsdata's Avatar
split wire loom, 3 different sizes cheap at Harbor Freight... I used some of all three sizes
first thing I did was crawl underneath and wrap all the bare electrical wires and tie them down with nylon ties on my new 183
took a couple of hours but well worth it for piece of mind
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 08-13-2015, 08:43 PM   #3
mud yapster's Avatar
Yep you have to take the FR quality to the next step yourself or stuff may happen.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-14-2015, 09:47 AM   #4
Wow, thanks for identifying this potential problem... under the RV I go.
NJ-Bill is offline   Reply With Quote
Old 08-14-2015, 11:38 AM   #5
Trbomax, I spent a whole Saturday under my camper doing the same thing. Put the slide out and see how those wires look also
2015 274 RK LIMITED <'{{{{><
captainperry is offline   Reply With Quote
Old 08-14-2015, 11:43 AM   #6
Flybob's Avatar
A very similar problem can occur with propane line hose especially around the tank mount on the front of TT. For a simple fix take an old piece of garden hose cut to 6"-8" and slit lengthwise then slip over the propane hose everywhere it is close to a frame member. You can use tape or Zip tie to keep it from sliding along hose. Check annually and replace as needed. Inexpensive and very effective.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-14-2015, 12:04 PM   #7
Flybob is correct. The propane hoses leaving the front of the trailer and running towards the rear go up/under a lot of braces in that area
Old 08-14-2015, 12:08 PM   #8
rhart's Avatar
I've seen so many of these shocking reports that I'm wondering if these units are being produced in South Tijuana by deaf dumb blind folks. These are not just annoying little fixes, many are serious safety issues!
rhart is offline   Reply With Quote
Old 08-14-2015, 12:10 PM   #9
@trbomax,
i do not believe what I see, very serious issue, grrrrrrr ....:-(
Prism 24G is offline   Reply With Quote
Old 08-14-2015, 12:15 PM   #10
rhart's Avatar
I was a couple weeks away from ordering a Class C 3011 when a noticed a few threads like this. After finding many more I decided to never buy a FR product.
