Old 04-21-2014, 07:58 PM   #11
Ok, got it! Taylor Park Colorado! Another for the bucket list! Looks awesome!
astagman is offline   Reply With Quote
Old 04-12-2015, 08:58 AM   #12
It appears I will be the Guinea Pig.
Sounds like most people are loading cycles into their 27RR's, but for those loading side x sides, an RZR 1000 will fit. Have about 5 inches in the front and 3 inches in the rear with the door closed. No bumpers nor roof on the RZR currently. The rear screen was not an issue, good inch or two clearance to door frame top, and 2-3 inches clearance on the sides while going through the door opening.Click image for larger version
Name:	ImageUploadedByForest River Forums1428846997.663854.jpg
ID:	73979Click image for larger version
Name:	ImageUploadedByForest River Forums1428847014.230190.jpg
Sent from my iPad
Old 04-12-2015, 09:13 AM   #13
Timex's Avatar
Are you going to tie the sidexside down? Even if you do, some pads/cushions or even some pool noodles to keep the sides/tires from rubbing.
Maybe they won't be needed but I'm funny that way.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 04-12-2015, 10:19 AM   #14
Yes, tied down with 6 ratchet straps to the D rings in the floor. Once loaded, there is 18" or so clearance to the sides. For OAL, once bumpers are added, we'll need padding for sure.
Sent from my iPad
Old 04-12-2015, 01:09 PM   #15
Timex's Avatar
Good deal.
Old 04-13-2015, 09:39 PM   #16
I loaded my Victory Cross Country Tour into my 27rr tonight for the first time. I was pretty nervous after reading of some nightmares. I had absolutely no problems with clearance. I put a 2x6 under the ramp just to get a little extra clearance and rode it up with no problem. Tied it down and am ready for our weekend trip. I also measured the tongue weight and was sitting at 850. Adding the Vic took off 150 pounds of tongue weight because the garage is behind the dual Axles. I'm still sitting about 12% or more tongue weight. Really happy with this unit. The only question is what to do with the back table when the bike is loaded. Any thoughts?
Rhoadzie is offline   Reply With Quote
Old 04-14-2015, 07:36 AM   #17
I stand my table in front of the left wheel well. I made a couple of brackets that hold it to the wall. Some of my cushions fit between the table top and the table legs, the other cushions fit standing on end in the adjacent corner between the bathroom door and the rear outside door. I found a picture you might be able to make out the table leg and part of the table top. When I get my camper back from the dealer (in for warranty work) I can take a better picture.
comfun1 is offline   Reply With Quote
Old 04-14-2015, 07:38 AM   #18
In looking at my picture, I believe it is right behind my left wheel well.
Old 04-14-2015, 07:10 PM   #19
Thanks. I will try to do the same thing. What brackets did you use to secure it?
Old 04-15-2015, 09:32 AM   #20
I can't remember for sure, but I'm planning on going after my camper next week and I will be able to get a better picture. My dealer is about 70 miles from where I live.
