Old 10-28-2015, 05:00 PM   #1
Lighting solutions for the Vengeance Garage
I got a Vengeance 31v but I am sure this pertains to any of the Vengeance models. In my garage I have the two jack sofas and a sleeper and when they are up the lightening is terrible.
Has anyone addressed this issue and come up with acceptable solutions for this?
I bought a little portable LED touch light but it is worthless. Would love to be able to get enough light to able to either work, eat, or play cards.
Toss out you solutions and ideas.
thanks
MarcH is offline   Reply With Quote
Old 10-29-2015, 12:50 PM   #2
Man thanks for posting. We have the same set up in our garage( 320a) & you saved me some money, I was going to buy the same lights you did. Sorry I don't have a solution but Iam hopefully someone else will chime in with one.
Brian
2017 GMC Sierra 2500 Duramax L5P
2016 Forrest River Vengeance 320a.
LB TN is offline   Reply With Quote
Old 10-29-2015, 05:07 PM   #3
I think I have it figured out. To add them just have to get creative with running the wires.
I may do a write up on it in the near future.
Old 10-29-2015, 06:26 PM   #4
When the dinette is down for eating a meal or playing a card game to me there needs to be lights installed on the bottom of the top bunk. Which in our unit that would light that area up good.
Brian
Old 10-30-2015, 12:34 PM   #5
A32Deuce's Avatar
Strip led lighting 12 volt, run through a remote controlled dimmer. Come in various lengths.
A32Deuce is offline   Reply With Quote
Old 11-02-2015, 12:57 PM   #6
How about something like this: 12-Volt Universal Porch/Utility Light with Switch – White Base - Husky 51226 - Light Fixtures - Camping World
Or any of there surface mount lights, for a bit more you can even get LED.
For wiring, go to Home Depot or something similar and get the low voltage wire. I use that stuff for everything! You should be able to tap into the light that is there and run it out to where you can mount the light. And if the light you tap into is switched no problem, leave the switch off on the new light until you need it.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
Old 11-07-2015, 10:10 PM   #7
I home ran the wire to the switch and bought some surface mount to hide the wires. I bought two light fixtures. I did it all for around 65 bucks. I will have to take some pics.
Here is a link to the surface mount loom similar to this.
Shop Mono-Systems, Inc. 9-Pack 0.5-in x 144-in Low-Voltage White Cord Cover at Lowes.com
Old 11-10-2015, 08:04 PM   #8
This is what I did
ID:	94058   Click image for larger version
ID:	94059   Click image for larger version
Marc Haught
15 Vengeance 31V
15 Ram 2500 6.4
Old 11-11-2015, 09:10 AM   #9
Nice job looks great.
Old 11-11-2015, 06:33 PM   #10
I mounted them at the center 65" that way it is out of your eyes if you are sitting at the table and when you lower the bed it is just above the bed.
I wished I would have done this a long time ago.
If you're close to 6 foot like me I am sure you have conked your head on the sofa braces more than once. If you notice in the pic you see I purchased some 3/4" pipe insulation. They have adhesive already on them so easy and cheap modification. Hopefully no more bumps on my head.
Marc Haught
15 Vengeance 31V
15 Ram 2500 6.4
Old 11-15-2015, 04:57 PM   #11
Toothpick's Avatar
That gives me some ideas...
I have the 25v.
I'm just going to have to figure out where to tie into the 12v power.
Joy & Mel
2022 XLR Nitro 351
2022 Ram 3500HD MegaCab BigHorn 4x4 6.7L
2020 Indian Roadmaster
Toothpick is offline   Reply With Quote
Old 11-16-2015, 10:03 AM   #12
Mele, The 12 volts is home ran right behind the light switches.
Marc Haught
15 Vengeance 31V
15 Ram 2500 6.4
Old 11-16-2015, 11:19 AM   #13
Toothpick's Avatar
The 25v doesn't have switches there.
Joy & Mel
2022 XLR Nitro 351
Old 11-16-2015, 09:22 PM   #14
I think he meant the switches on the lights.
BIRDS AREN’T REAL
Old 11-16-2015, 10:42 PM   #15
We have a XLR but had the same problems and I solved the problem with 2 12 LED tape light strips mounted under the top bunk. I picked the p power and ground from the lift motor and just used the automotive plastic wire loom cover to run my wires to the switch and to the lights. Had to leave some loose for the top bunk to move up and down.Click image for larger version
Name:	ImageUploadedByForest River Forums1447731715.926238.jpg
ID:	94448Click image for larger version
Name:	ImageUploadedByForest River Forums1447731754.918423.jpg
the.wilsons is offline   Reply With Quote
light
