If it's anything like our 26RR, the single cable from the outside comes into a splitter located above the living room TV. I took the antenna plate out and gently pulled the cables until the splitter came out. Ours has one orange cable from the outside and 4 white ones (IIRC)....one from the antenna, one to each TV, and one outside where the TV mounts.
Also, if by "lost" you mean that one day you had a signal and the next you didn't, make sure that your antenna amplifier isn't on....ours has a green light when it's on.
2016 26RR and a 2018 OR371MBH
