Old 08-22-2007, 07:05 PM   #1
Sick Boy
bdscoot's Avatar
Maiden Voyage
Hey Gang,
First trip last weekend. Ended up staying until Monday. No big issues. T.V. antenna crank fell off in my hand but it was just a loose set screw.
The "Equalizer" can be embarrasing!!! Hard to sneek away early in the morning without waking the camp ground.
Already planning our next trip. Can't believe it's time to go back to work.
Be safe
ID:	346   Click image for larger version
ID:	347   Click image for larger version
2002 GMC 1500HD, 6.0/3:73
2007 27/DFWP
2004 Hardcore2 Chopper
2001 Indian Scout
2003 Buell Blast(mommas)
1986 883 Sporty(mommas)
1972 Yama Verticle twin hardcore chopper
TTR 125/225 Dirt bikes
Latest addition-2007 Ninja600R(18yr old sons bike)
We love our motorcycles!!!
19 yr old daughter in college
Awesome wife of 20 yrs just finished nursing school
Life is a highway
bdscoot is offline   Reply With Quote
Old 08-22-2007, 09:30 PM   #2
Biker trash
fxstsharleyrider's Avatar
Looks like biker trash to me.
Cherokee bike rally is sep 7,8,9. We'll be at the KOA. come on up. Tim http://www.cherokeerally.com/
fxstsharleyrider is offline   Reply With Quote
Old 08-23-2007, 06:34 AM   #3
so which scoot is under the cover??
aintgotnun is offline   Reply With Quote
Old 08-23-2007, 07:09 AM   #4
RAC
Greg, if the Buell doesn't get one, My guess is the Indian or the harley. LOLOL
Congrats on the trip. I am trying to figure out why the equalizer was "embarrasing" , unless you didn't raise the tongue high enough to let the bars easily slip in place rather than clunk and have to break "balls" trying to leverage them in.
RAC is offline   Reply With Quote
Old 08-23-2007, 07:24 AM   #5
My crank also fell off, and after looking at the top of my trailer the boot around the cable to the antenna had worked up out of the groove, but I think there was enough caulking inside that no real damage.
DW of 12 yrs 6yr old girl, Twin 9yr old girls, 9yr Old boy (10 months between the Three)
2010 Suburban 1500
2006 Sea Ray 185 sport
On the hunt for a new travel trailer
wvsteve is offline   Reply With Quote
Old 08-23-2007, 10:04 AM   #6
Sick Boy
bdscoot's Avatar
Scuba Steve nailed it. The Indian gets the cover.
The equalizer hitch works great but did creak/moan while turning. From what I have read in this forum, the noise is typical. It just seems a little excessive to me. I will recheck my measurements when I return home.
Can regular wheel bearing grease be used on the hitch or do I need the special "Equalizer" grease?
Thanks All
2007 27/DFWP
2001 Indian Scout
Life is a highway
Old 08-23-2007, 10:29 AM   #7
RAC
NOOOOOOO!!!!!!!!!!!!!!
Ok that said, here's why.
The Groan/pop/moan you hear is friction, which is the main ingredient in anti sway. This is what's keeping the trailer from rapidly moving laterally in cross wind, etc. You don't want to lube the flat point where your bar comes in contact with the brace support. The lube point is where your bar inserts into the hitch. the tiny gap between the swinging part and the hitch framing. This will help you move your bars side to side easily. 32" from the center of the Ball socket to the center of one of the holes on the brace is perfect. (Mine is a 1200/12000 lb hitch.....) Check on a flat surface for a level appearance between your TV and TRLR. Adjust the Supports on the trailer frame accordingly to get this.
Old 08-23-2007, 10:57 AM   #8
Thanks All
Guess I should have figured the Indian as the Sporty and Buell belong to "Momma".
I'm with Steve on the grease.
Old 08-23-2007, 11:01 AM   #9
powerboatr's Avatar
"crank fell off"
sure it wasnt with a person of unsavory pratices
ours did the same thing on our second run
i went to pull the covers back and heard a THUNK and found the handle laying on the floor
little set screw gave way
oh nice set up
and scooters
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 08-23-2007, 11:03 AM   #10
RAC
You sure you want to be with me on this Greg? Afterall I am blonde.
cherokee wolfpack
