Old 04-16-2015, 07:41 PM   #11
We just installed the Biker Bars, awesome product. No more straps!!
Krawler is offline   Reply With Quote
Old 04-16-2015, 09:26 PM   #12
Taranwanderer's Avatar
Yeah, and getting that bottom plate on without you here tonight was a blast, let me tell ya!
So, the BB is installed, it looks like it'll do what it's supposed to do. DW is already bugging me to remove the wheel chock on that side. I'm sure I'll be installing another one on her side when she sees it in action. The install was a bear--after doing Krawler's, we figured the second time would be easier, learning curve and all. Wrong! I had to tweak one of the lower mounting plates to make it fit along the frame, since that was where the hole needed to be. Also had to tweak the frame slightly to fit the main bolt down through. (Tweak=grind off.). Took a while, now I'm anxious to go somewhere with it!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 04-17-2015, 06:08 AM   #13
BUT, if you would have measured more underneath the trailer before drilling, you would have avoided all of the problems .
Old 04-17-2015, 06:56 AM   #14
Yep--if we hadn't been so set on centering it and moved it over a half inch, a lot of that would have been avoided. We know now for the other side when she orders hers...
Old 04-17-2015, 07:19 AM   #15
muddyrode's Avatar
i took the one i bought from harbor freight put eye bolts on the front and two clevis's on the back so i could strap that down to the existing tie downs as did not want to drill holes in the floor when i had my TH
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 04-17-2015, 11:44 PM   #16
ChipBruce's Avatar
Kmac can you post pictures?
Chip Bruce, RPh
Kansas City, MO
ChipBruce is offline   Reply With Quote
Old 04-17-2015, 11:49 PM   #17
northstar1960's Avatar
Originally Posted by roadrash2012 View Post
Hmm. I'll have to take a look at that one. What ever I get I'll probably have to modify and make free standing. Since I was told not to drill holes or I would void warranty. . And thanks I can't wait to get it
setting a motorcycle chock and fastening it to the floor can not void a warranty
northstar1960 is offline   Reply With Quote
Old 05-16-2015, 02:54 PM   #18
I use the harbor freight one also - just had hard time getting bike out of it with wife having to stand on it when I need to get goldwing out. Will be getting turn buckle bolts to attach wheel chock to d rings on floor next time. It works great making it possible to land bike and get off and it wont move while strapping it down. I also put horse pad rubber mat down to protect floor. **why does this site keep flipping one pic upside down??***
RV Leveling Blocks Built for Indestructibility
ID:	77112   Click image for larger version
ID:	77113   Click image for larger version
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 05-16-2015, 03:30 PM   #19
ChipBruce's Avatar
The picture in the HF directions was pretty bad and I installed the rocker backwards. I flipped it around and it worked better getting it out of the chock.
Chip Bruce, RPh
Kansas City, MO
Old 05-16-2015, 05:11 PM   #20
Im pretty sure its assembled right - my front tire fits very snug into it. Wont hurt to double check it though. Thanks
2006 Honda Goldwing
mount
