Old 05-16-2015, 05:15 PM   #21
Motorcycle mount
If you have the swivel (rear) section on wrong, it won't pivot up when not in use.
I had the same problem, so I took a hi-lift jack and opened the front up more. More of a "U" shape instead of the tighter "V". Still sticks, but not as bad.
Still loving the ease of the Biker Bars
Krawler is offline   Reply With Quote
Old 05-16-2015, 05:26 PM   #22
Ill try that - it is on correctly. Thanks for the info!!
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 05-18-2015, 11:51 AM   #23
Originally Posted by empa1968 View Post
This is what I use, works great and I didn't have to modify the floor. they'll customizr the length to fit your toy hauler.
Bolt It On, Serious Racks
I made my own version of this and it works great for 2 bikes (one dresser, one sport bike). I just took a piece of 2x4 tube steel, notched and welded some 4x4 angle iron (for the wheels to fit into). Then I just set this on 2 jack stands, bolt it down with some J-bolts, lock washers, and wing nuts; and it's good to go. Spent maybe $100 total and it holds the bikes solid without having to modify / drill the trailer at all. I'll try to get some pics asap.
klarowe is offline   Reply With Quote
Old 07-18-2015, 10:23 PM   #24
Harbor Freight chock without a single hole in the floor.
NJ-Bill is offline   Reply With Quote
Old 07-21-2015, 09:34 PM   #25
nj-bill can you show me a close up of the two by fours at the tie down area cant get a good close view of that area to see mounting at the tiedown thanks
th
16grey is offline   Reply With Quote
Old 07-22-2015, 09:10 AM   #26
th
Sure. That is a u-bolt running through the wood. It is the same width as the chock.
After this picture, I painted the wood blocks with black bed liner. From a few feet, it looks oem.
Old 07-29-2015, 09:42 PM   #27
Retired Techie
Another thought. Weld a bolt on the bottom pointing forward. Slide it through the hold down loop, add a washer and lock nut. I did that to the middle front of my HF, holds the wing just fine. Threw the rocker away. To small to fit wing tire. 4 tie downs , two forward----two back front wheel in chock and frame block of 2x4 's in front of rear wheel..
moligney is offline   Reply With Quote
Old 07-31-2015, 06:19 AM   #28
Nice ideas I'm gonna try these and if I figure out anything easier I will post
roadrash is offline   Reply With Quote
Old 08-25-2015, 12:01 PM   #29
NJ-Bill, I did like your idea for the front wheel chock. I have used these HF floor chocks in my garage for years. I do not have them bolted to the floor, but mounted on a 1x12 for the full length and glued HF tool drawer mat to the bottom side. does not slide on the garage floor when rolling the bike on or off. I used this same idea for the toy hauler.
Bottom with the HF tool drawer mat
I used a 6 inch in length 2x4 to catch the tie-down loop and a 1-1/2 U-Bolt (which measures 2" inside) to capture the HF Wheel Chock.
The 1x12 lifts the chock 3/4 of an inch to allow the U-Bolt to pass under and not touch the floor. No drilling in the Chock assy.
When I got to Denver this last weekend I rolled the bike and tie it down it did not move.
racenviper is offline   Reply With Quote
Old 09-08-2015, 01:03 PM   #30
Racenviper,
That looks great. I may copy the wood underneath.
Thanks,
Bill
mount
